Brake Pedal Assembly - Booster Selection
Over the years I somehow misplaced the brake booster and master cylinder. I understand these are pedal-specific, so I want to be sure I order the correct ones.
The pedal stamping on mine is:
D3TA-AA
1 5 73
I’ve noticed other posts reference D3TA-2455-AA, but mine doesn’t include the “2455.” Is that normal? Should this be treated as D3TA-2455-AA, or am I missing a different part number?
I assume this pedal is from a 1973. Is there any advantage or disadvantage to using this setup, or would it make more sense to swap to a later-year pedal/booster/master combination while I’m here? I’m not clear on the functional differences.
Ive also got a parts truck (350) with a brake assembly stamped as D3TA CA. It has a booster but not sure if the condition. Was told it ran and drove before they pulled engine, but you know how that goes.
https://www.battlebornbrakes.com/pro...ore-master-f3b
