Transfer case drain plug not tight
Old Dec 11, 2025 | 02:47 PM
senecagreen's Avatar
senecagreen
I serviced my 2022 F250 transfer case today.The fill plug was tight. The drain plug barely snug. 88k miles, when I bought it at 64k miles I did not see in the service records that the transfer case had been serviced but it must have been because I doubt it left the factory that way.
I got lucky.
Old Dec 12, 2025 | 08:27 AM
speakerfritz's Avatar
speakerfritz
A lot of mechanics do not want to over tighten because the area around the plug will crack.
proceed with caution.
Old Dec 12, 2025 | 09:11 AM
senecagreen
I tightened it with a 4" long stubby 3/8" drive ratchet by hand 👍
Old Dec 12, 2025 | 05:03 PM
OBS460's Avatar
OBS460
?? My 2022 has 1/2" square plugs. I was just under the truck today doing an oil change and checking everything for leaks.
Old Dec 12, 2025 | 07:55 PM
1olddogtwo's Avatar
1olddogtwo
Well, I can tell you for example with an aluminum case, it is easy to over tighten. Example ,my Polaris buggies differentials, transmissions etc, the torque is like 6 to 8 lb, You want a crank on an aluminum case, go for it. The next time you pull that plug out the threads will be in it.
Does anybody know what the torque rating is for the transfer case?
Old Dec 12, 2025 | 09:08 PM
senecagreen
Thats good advice.
The fill plug was a lot tighter when I removed it than the drain plug and I didn't tighten the fill plug up as tight as it was when I reinstalled it.
Since the spec is 20ft lbs I used a 4" long stubby ratchet so I wouldn't over tighten it and tightened it by hand to about a spark plug level.
Old Dec 12, 2025 | 09:28 PM
willynilly's Avatar
willynilly
its pipe taper thread. if you got all stupid with the ratchet you can screw up the threads or worse. should of used small bit of thread tape and just snugged it up
Old Dec 12, 2025 | 09:31 PM
OBS460's Avatar
OBS460
I put Teflon tape on mine when I changed the fluid 30k miles ago and I didn't torque them but just snugged and they don't leak.
Old Dec 12, 2025 | 09:33 PM
willynilly's Avatar
willynilly
yep tapes the way to go
F150_4x4
1997 - 2003 F150
Sep 10, 2025 09:20 PM
Boaterguy
Jan 30, 2025 07:45 PM
MeTo
Nov 28, 2023 04:40 PM
otpracer100
Aug 20, 2005 12:11 AM
