BW1356 T Case question
Old Dec 12, 2025 | 10:15 AM
BigBlue2's Avatar
BigBlue2
If your speedometer is cable driven you can probably use a cable from your 86. I understand that at some point Ford got rid of the cable and went electronic.
Old Dec 12, 2025 | 11:03 AM
Tillylamp's Avatar
Tillylamp
well, stone the crows my friend....it seems the electric shift came in 92, that`s me sorted with this TC then.....
Old Dec 15, 2025 | 04:54 PM
tecgod13's Avatar
tecgod13
Electric shift was possibly just an option. Electric shift has a motor on the side with wires, I want to say the motor mounts with 3 bolts. Manual shift would have a large lever that goes thru the floor of the truck that attaches to a large bolt on the side of the transmission with a linkage that runs back to the transfer case that move a crankshaft that goes where the motor is on electric shift units. I think the cases are nearly identical except for how the motor attaches. The internals would be the same except for the shaft going thru the case.
Regardless of the shifting, if you want your speedometer to work, you need a whole in the side of the tailshaft of the transfer case for the cable to go thru. The later units, after electric speedometers would still have the boss cast into the case, but no hole. I don't know if there are internal differences on the output shaft. It might be possible to drill out a newer case and add the speedometer ring to the tailshaft if needed. Would be easier to find the correct unit in the junkyard thought.
Old Dec 18, 2025 | 11:19 AM
Tillylamp's Avatar
Tillylamp
thanks for that info, but i do have the right one, the one i have has the hole for the speedo cable in the tail housing, this was my joy when i found out the t case i have is dated 1986 on the tag, the swap is on hold for a while now as winter has arrived, snow and -28 wind chill, no fun laying under a truck in that weather. so i will be indoors now making a start on my motorbikes ready for summer.....lol
Jim40216
Jun 12, 2018 07:31 PM
Drakedog
Apr 24, 2017 03:34 PM
Brock909
19
Sep 12, 2011 01:45 PM
90f150302
Oct 2, 2006 12:34 PM
Diamond Jim
Feb 14, 2006 12:31 PM
