Sponsored by: Real Truck
Od light flashing
Old Dec 6, 2025 | 11:46 PM
Joshua.w's Avatar
Joshua.w
1st Gear
Od light flashing
I have a 2003 7.3 and its missing 3rd gear occasionally and it results in a overdrive light flashing. I just put a tranmission in it and ive already changed the solenoid it has a ats tourq converter and it throws a 3/4 solenoid code the truck has a 88/68 turbo unknown injectors but bigger then stock and a airdog fuel system. it had a ats tranmission before I swapped it could it be a valve body issue?
Old Dec 7, 2025 | 12:17 PM
marksman76's Avatar
marksman76
for starters:
google overdrive light flashing
and then ther is this;
https://www.ford-trucks.com/forums/5...-to-flash.html
Old Dec 7, 2025 | 01:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, it can't be a valve body problem. That won't set a solenoid code.
There are two things that can set a solenoid code, a bad solenoid, or a damaged wire to the solenoid. I'm betting on the wire.
Farmer Brad
Feb 21, 2024 06:01 PM
7.3smoker
Apr 5, 2022 10:46 AM
Dreim
Oct 25, 2021 10:30 AM
bigdavesohc
1983 - 2012 Ranger & B-Series
Sep 21, 2006 12:30 PM
tim_30043
Mar 28, 2003 07:16 PM
