Door Ajar Sensor
Old Nov 30, 2025 | 05:37 PM
pbauer's Avatar
pbauer
4wd Low
Door Ajar Sensor
2022 F250 XLT
About a month ago, the passenger door started acting up. When I open it, the truck correctly shows the door as open, but once I close it, it doesn’t always register that it’s shut.
If the truck sits for a while, the issue clears—until I open the passenger door again. It’s intermittent, and it has never falsely shown the door as open before I actually open it.
I pulled back the wiring boot between the door and the chassis and didn’t see any obvious damage. This seems to have started when the weather turned colder.
Any ideas on what else I should check?
Old Nov 30, 2025 | 05:50 PM
scraprat's Avatar
scraprat
Top Answer: 5
Yes, the door ajar sensor in the door attached to the latch mechanism.
Old Nov 30, 2025 | 05:52 PM
pbauer's Avatar
pbauer
4wd Low
Any idea how I check that or how it works? Can I spray some type of cleaner on it or do I need to take the door apart?
Old Nov 30, 2025 | 06:08 PM
scraprat's Avatar
scraprat
Top Answer: 5
Go to YouTube and put ford superduty door ajar sensor.
I just did it on my 2016 F350.
Old Nov 30, 2025 | 10:59 PM
muisejt's Avatar
muisejt
you need to take the door apart to get to it, steps to do it are here: https://www.ford-trucks.com/forums/1...l#post21659112
Jamie Arceneaux
Mar 16, 2013 09:05 AM
fireball318
Mar 27, 2009 05:22 AM
Joker50
May 28, 2008 03:29 PM
buckshot047
Jul 6, 2005 03:38 PM
