Misfire or backfire?
Old Nov 25, 2025 | 07:00 AM
moodperson's Avatar
moodperson
I posted this in another forum, but was advised to repost here since it is about a 6.0...
I have a 2004 6.0l truck with 47,000 miles on it. Sometimes when it starts, it lopes, then goes into a fast idle, but eventually settles into a normal idle.
But I took it out the other day and it started making a "backfire" noise under the hood upon hard acceleration. Normal acceleration it doesn't do it.
After a while, this behavior stopped and I could hard accelerate and everything is great. But then, it came back doing it again. I did notice it smoothed out temporarily when I put in a fuel additive, but that is still in the tank.
Anyone have a clue what is happening? It isn't backfiring out the exhaust. Seems to be under the hood. Thanks for any ideas!
Old Nov 25, 2025 | 04:47 PM
runthatjunk's Avatar
runthatjunk
Intake valve hanging open a bit?
idk haven't heard of that one before
Old Nov 26, 2025 | 08:32 AM
joe blow's Avatar
joe blow
Sounds like a sticky EGR valve (if you still have it in).
Pull it out and look at its condition, and also look in to the intake plenum to see its condition (wet, full of oil residue, crud buildup etc).
Old Nov 26, 2025 | 04:42 PM
moodperson's Avatar
moodperson
Sticky EGR? Have you seen this behavior with EGR valves? Why would they cause a "popping" sound and momentary hesitations? Just asking, since I am new to the 6.0
Thanks.
Old Nov 26, 2025 | 08:15 PM
BLADE35's Avatar
BLADE35
Codes
gauges
the only popping noise common to these would be the pop from intercooler boot blowing off under high boost this isn’t that
Old Nov 28, 2025 | 08:04 AM
moodperson's Avatar
moodperson
No codes at all.
Old Nov 28, 2025 | 08:08 AM
bismic's Avatar
bismic
What are you using as a scan tool?
Old Nov 28, 2025 | 08:47 AM
moodperson's Avatar
moodperson
Using a software too with an OBD2 bluetooth plug. The software is called Torque Pro
Old Nov 28, 2025 | 08:58 AM
bismic's Avatar
bismic
We are familiar with Torque Pro. It is usually pretty good at retrieving most/all codes.
Doesn't sound like an issue w/ a sticky EGR valve, and a sticky EGR valve usually produces a code or two.
For that reason, I am thinking an injector might be acting up mechanically (if it is acting up electrically, it usually will also throw a code).
What oil are you using?
When was it last changed?
What is your ambient temperature in the mornings?
Five suggestions:
1. Get a sensor and gauge for fuel pressure.
2. Take a video of the issue and post on youtube (put a link in this thread).
3. Post a pic of the top of your engine (be sure to include the oil filter in the pic).
4. Verify that all three FICM connectors are plugged in.
5. Continue using a quality fuel additive - just to see if the improvement you saw really MIGHT BE from the additive, or that it was only a coincidence.
Old Dec 9, 2025 | 06:49 PM
moodperson's Avatar
moodperson
Five suggestions:
UPDATE: I drove around a lot today and noticed that the sound only happens in a coule of conditions.
First, it doesn't happen under mild acceleration
Secondly, it ALWAYS happens in the RPM range of 1800-2000 RPM and then only under hard acceleration.
Thirdly, the truck purrs normally and the engine doesn't throw codes.
Finally, on cold startup at about the one minute mark after start, the truck typically will go into a high idle (1200 RPM) very suddenly. It will gradually go down to normal when the engine gets up to operating temp.
Could all these issues be related? If so, how?
Thanks.
moodperson
Nov 26, 2025 06:25 AM
Jtegg007
2004 - 2008 F150
Oct 30, 2023 01:53 AM
6.oh_Azzy
Jul 8, 2023 09:26 AM
TiffCluck
Sep 9, 2021 08:35 PM
MrBeef
Apr 25, 2019 02:12 PM
