I have a 2004 6.0l truck with 47,000 miles on it. Sometimes when it starts, it lopes, then goes into a fast idle, but eventually settles into a normal idle.
But I took it out the other day and it started making a "backfire" noise under the hood upon hard acceleration. Normal acceleration it doesn't do it.
After a while, this behavior stopped and I could hard accelerate and everything is great. But then, it came back doing it again. I did notice it smoothed out temporarily when I put in a fuel additive, but that is still in the tank.
Anyone have a clue what is happening? It isn't backfiring out the exhaust. Seems to be under the hood. Thanks for any ideas!
I'm not sure how I would do audio. Not a bad idea, but the sound is somewhat muffled from within the cab. I get it - it's hard to describe a sound, but it's like a dull popping sound, as though some of the cylinders are misfiring but not all of them. And they only misfire when hard accelerating.
FYI
Common for these to lope and go into high idle when cold
oil fired inject is cold blooded in winter high idle warmup in park is programmed by dealer under certain ambient temp conditions and should also be equipped with a block heater to plug into a 110ac outlet
Backfire is uncommon
does the truck actually stumble/hesitation upon the backfire event or just a popping noise in engine bay
FYI
The more I think about this it sounds like a failed injector (stiction). You'd need to do an injector contribution test, not something every shade tree mechanic can do.
There are preventative things you can do to prevent this, such as running full synthetic engine oil and/or adding an oil friction modifier like Archoil's AR9100. However, once it reaches this point there's very little you can do besides replacing the injectors...but you'd need to know which one it is, which is where the contribution test comes in.
