overdrive shuts off by itself
Old Nov 13, 2025 | 09:13 PM
r509220's Avatar
r509220
5th Gear
My truck is a 1997 F250 with an auto trans. It has 146000 miles. My overdrive shuts off by itself and takes numerous pushes on the button to turn back on .It does not blink like all the other posts I have seen about on this site. When I start the truck it is already shut off and I can't reset it till I start driving it. Then going down the road it shuts off again, over and over again. I am talking it will do that about 10-12 times in about 10 miles. I have had it in a shop 3 times (not a dealer) for this and they replaced some type of module in the steering column. But it still does it. any help would be appreciated. By the way it is in the shop now and he can't figure it out. It's been there for 3 weeks.
Old Nov 14, 2025 | 07:04 AM
z31freakify's Avatar
z31freakify
Check the wiring for the brake switch barke fluid level sensor and wiring going to the brake lights.
Old Nov 14, 2025 | 01:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Take the cover off the steering column. Inspect the wires where they enter the shift handle. Most likely, one or more has a spot where the insulation has been worn off and the wires are shorting, causing your issue.
Old Nov 18, 2025 | 10:33 AM
r509220's Avatar
r509220
5th Gear
I will check all of that when I get the truck back from the shop.
Old Nov 18, 2025 | 10:37 AM
r509220's Avatar
r509220
5th Gear
The shop that has my truck already replaced that part and this is the third time it has been in for this. I will update when I get the truck back and I get it fixed.
Old Nov 18, 2025 | 08:03 PM
Mark Kovalsky
They replaced the shift handle or the wiring that plugs into the shift handle?
Old Nov 18, 2025 | 08:16 PM
r509220's Avatar
r509220
5th Gear
They replaced the wiring, not the shift handle.
Old Nov 18, 2025 | 08:45 PM
Mark Kovalsky
That's unusual. I have nothing else to add to this thread.
Old Nov 19, 2025 | 10:45 AM
r509220's Avatar
r509220
5th Gear
I should have been more clear about the wiring. They replaced a switch in the steering column. I never saw it so I don't know if the wires from the shift handle plug into or not, but I assume that to be the case.
Thank you everyone for your input and suggestions.
Old Nov 20, 2025 | 03:24 PM
Mark Kovalsky
So they replaced the OD OFF switch, which almost never fails.
Remove the cover from the steering column. Inspect the wires where they plug into the shift handle. It's a common occurrence for these wires to wear through the insulation and short circuit. This will cause the OD OFF to come on at random times.
Old Nov 21, 2025 | 09:51 PM
John11.25's Avatar
John11.25
This happened to me and I replaced the handle and switch, to no avail. I sent my PCM to Diesel Technologies of Chattanooga and they sent me a rebuilt one that corrected the problem. Just a thought.
wameyer
Nov 15, 2013 10:32 PM
Mr Clean
Electrical Systems/Wiring
Aug 14, 2007 07:42 PM
THRODS
Modular V10 (6.8l)
13
Apr 14, 2005 09:57 AM
adunham
2004 - 2008 F150
Sep 23, 2004 01:48 PM
rrich600
Nov 12, 2003 12:48 PM
