Overdrive button question
Old Sep 22, 2004 | 11:55 PM
adunham's Avatar
adunham
For the last month or so, I've tried to make use of the overdrive button per the instructions in the owner's manual (in an attempt to get the best mileage possible). That is to say, when I'm on the highway, I have the overdrive activated; when I'm driving on surface streets, I have it deactivated. So I have to wonder: why is the overdrive set to activate when the truck is turned on? I think its safe to say that nobody turns his truck on in the driveway, pulls forward, and is suddenly on the highway. Most of us have to drive a little bit on surface streets to get to the highway. Above and beyond that, I do most of my driving on surface streets, just around town. It seems to me like overdrive would be something you'd want to activate only when getting onto a highway, not upon startup. The very first thing I do when I start my truck is turn the overdrive off. Does anyone know why it is set up like this?
-aaron
Old Sep 23, 2004 | 04:54 AM
samia's Avatar
samia
I only shut off overdrive when towing in the hills. You shouldn't need to shut it off in town. I don't think your truck shifts into overdrive until your going fast. Just my 2 cents....
Steve
Old Sep 23, 2004 | 05:02 AM
LAL426's Avatar
LAL426
When I start my truck it is already off, and I have to put it on manually. That is the way that it has been with every vehicle that I have owned. Maybe have service look at it - sounds like your is set up the backwards way that it should be set.
Old Sep 23, 2004 | 05:12 AM
lardman's Avatar
lardman
Mine is always on at startup. I agree with samia.
Old Sep 23, 2004 | 08:45 AM
dentexman's Avatar
dentexman
I might be wrong, but I believe that the overdrive doesn't start out "deactivated" because of the EPA fuel mileage testing. If the F150's default setting was "overdrive off", that's the way the EPA would test it during both CITY and HIGHWAY fuel mileage tests.
Plus, if Ford set the system to require a button to be pushed to activate overdrive every time the truck was started, there would be lots of drivers that would never think to press the button, especially trucks in fleet or rental service.
I normally turn my overdrive off whenever I'm driving under 45 or 50 MPH for extended periods of time, such as stop and go traffic or driving within a city at speeds limits 45MPH or slower. I don't like the truck shifting into overdrive so quickly and not having any power when I press the GO pedal!
Old Sep 23, 2004 | 10:24 AM
adunham's Avatar
adunham
Dentexman - that was my first guess exactly.
Old Sep 23, 2004 | 01:30 PM
ctfordguy's Avatar
ctfordguy
I follow Dentexman method. Transmission seems to always be shifting with the OD on.
Old Sep 23, 2004 | 01:48 PM
KevinM's Avatar
KevinM
LAL426 - I think you have that backwards, OD off only happens when you actually deactivate it. Once deactivated, you turn off the engine and restart it is activated again until you or the driver actually deactivates it again! Always has been this way, both on my Lariat 2004 F150 and my previous Expedition.
Adunham - I don't deactivate it only when I tow.
deputydog03
Mar 16, 2016 09:42 AM
Jas_d
Oct 13, 2014 07:45 PM
rukowh
Jul 16, 2014 10:44 AM
JC21334
27
Aug 17, 2010 07:39 PM
