Help stuck in limp mode
Old Nov 12, 2025 | 03:58 PM
Easttown's Avatar
Easttown
4th Gear
2017 f350 4x4 dually. 6r140 trans. My P D R N D 2 1 Won't stay lit when the engine starts,so the truck dosent know what gear it's in. Limp mode not drivable. So far I've spent about $1000 trying to fix it. New Pcm from Ford, plus programming new internal trans wiring harness and new range sensor. No improvements.
Old Nov 12, 2025 | 04:56 PM
djousma's Avatar
djousma
Is the truck stock or tuned? How old are the batteries? What else have you tried? Does manual mode work? Have you pulled any codes that are present?
Old Nov 13, 2025 | 12:35 PM
Easttown's Avatar
Easttown
4th Gear
battery is almost new. no modes work. Codes for range sensor. It is new as is the p c m
Old Nov 13, 2025 | 04:18 PM
350Recon's Avatar
350Recon
https://www.ford-trucks.com/forums/1...ge-sensor.html
This guy seemed to have the same problem and found a fix in the link above.
Old Nov 14, 2025 | 08:07 AM
4x4k20's Avatar
4x4k20
did ford reprogram both the ecm and transmission ? with the gear lights not showing up correctly that seems like that a problem with the whole lead frame was it replaced or just the range sensor ?
Old Nov 14, 2025 | 11:54 AM
Easttown's Avatar
Easttown
4th Gear
everything was,programmed by Ford. 6r140 do not have a lead,frame
Old Nov 14, 2025 | 03:23 PM
acdii's Avatar
acdii
Crap, hims.,com jokes, or thats what she said wont help you on this one. You replaced the PCM because of what it was doing? Did you get codes, or was the PCM Fried? Has the power junction box been examined, because they tend to corrode and cause all sorts of issues and should be the first thing checked.
Old Nov 14, 2025 | 07:22 PM
Easttown's Avatar
Easttown
4th Gear
I changed the pcm,because thr problem was intermittent at times. I've checked the fuses. And seem ok but could be dealer. I've got an appointment Tuesday at another ford dealer to ck it out. Im really frustrated with this problem.
Old Nov 15, 2025 | 12:31 PM
350Recon's Avatar
350Recon
Looking more into it could it be this?
https://www.partsgeek.com/catalog/20...on_sensor.html
Old Nov 15, 2025 | 03:19 PM
acdii's Avatar
acdii
Not sure if this is the right one, but he has a video regarding the underhood fuse box issues.
Could be the issue. You have to remove the fuse box to check it, looking at it from above won't tell you if its bad or not.
Farrier1022
Feb 9, 2025 05:14 AM
PowerStrokin619
Mar 26, 2023 11:20 AM
plbigcoop
Mar 25, 2023 08:09 PM
altonlee
Apr 11, 2021 07:09 PM
Don Zielinski
Nov 26, 2019 04:58 PM
