Sponsored by: Real Truck
Trans temp probe failure
Old Nov 18, 2016 | 07:13 PM
plbigcoop's Avatar
plbigcoop
Question Trans temp probe failure
I have a truck issue i would like to run by y'all. I have an early 2003 F-350 KR cc dually 4x4 6.0 it's been mine for about three and a half years and I've replaced the trans temp probe three times and it has gone out again yesterday coming home from my deer lease. When I start the truck the trans temp goes full scale and goes into limp home mode can't go much faster than 45mph and after a while it will start shifting normally but each time I restart truck starts all over again. What I'd like to know is this a common problem and is their a fix? Thanks
Old Nov 21, 2016 | 12:50 PM
plbigcoop's Avatar
plbigcoop
To the top
Old Nov 21, 2016 | 12:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Have you checked the wiring? The problem could be in the wiring harness, not the sensor itself. The harness inside the trans that connects to the sensor has been know to fail.
Old Nov 21, 2016 | 01:36 PM
plbigcoop's Avatar
plbigcoop
Thanks for the reply. I had thought about changing the harness. I looked them up and the updated harness has a couple fewer conections. But I'll give it a go.
Old Mar 24, 2023 | 09:35 PM
PowerStrokin619's Avatar
PowerStrokin619
Deleted wrong post sorry.
Last edited by PowerStrokin619; Mar 24, 2023 at 09:37 PM. Reason: Wrong post.sorry.
Old Mar 25, 2023 | 08:09 PM
PowerStrokin619
Hey PLbigcoop....did you ever fix the problem? If so, what was the fix to correct it? I'm having similar issues and would like to hear your feedback. Thank you. -Steve
jonlb
6.4L Power Stroke Diesel
Nov 24, 2017 08:33 AM
brichert
Jun 20, 2017 06:32 AM
kpcsweeper
Sep 10, 2012 03:28 PM
phil9128
Feb 22, 2010 05:09 PM
timlewis642003
Apr 22, 2008 07:41 AM
