Cowl vent adjustment question
Old Nov 11, 2025 | 12:13 PM
Vegastype's Avatar
Vegastype
Is there any trick to adjusting the cowl vent throw when putting the bolt back in the arm? The passenger side of the truck comes down pretty nicely and fits somewhat acceptably flat. I know the new gasket's in there and pushing it up, I can push that down with some weight on it later on. But on the driver's side, I can't get that to come all the way down as far as the passenger. It seems like the lever is hitting the top of the cowl before it gets to the last notch.
I am also considering the possibility that over the years. Maybe that vent got twisted or bent, and it is what it is I figured I would post up and glean some knowledge from those that may know. Bottom line is the driver side does not sit at the same level of the passenger side Sorry in advance for not having a picture of it. I am not home at the moment.
Mike
Old Nov 13, 2025 | 07:46 AM
mtflat's Avatar
mtflat
I don't remember any particular alignment issues when I did mine.
Old Nov 13, 2025 | 07:50 AM
55F250's Avatar
55F250
AirForceVet
Question
Mike
Does it sit flat without anything connected to the vent?
Old Nov 13, 2025 | 08:50 AM
8pack's Avatar
8pack
Does the vent itself pivot freely or is it possible one side is binding due to rust or other issues. I would take a close look at those pivot points and verify everything is free and smooth.
And, even if it looks free and smooth lubricate the points with a good rust penetrator any way and move the vent up and down about 50x. Not WD40
Old Nov 13, 2025 | 09:07 AM
M2HB's Avatar
M2HB
The vent on my 55 has never been damaged or rusted and it binds more on one side than the other. I have tried penetrating oil with no success.
I think they just compressed one rivet tighter on one side than the other.
Old Nov 13, 2025 | 03:28 PM
56panelford's Avatar
56panelford
Could also be that the rubber gasket isn't set completely on that side..
jvmcc
Jun 11, 2016 06:22 PM
ZFLASH
Sep 4, 2012 06:10 PM
49Kustom
19
Jun 24, 2007 02:53 PM
mechmagcn
Sep 25, 2006 09:45 AM
cujo8
Apr 28, 2006 12:59 AM
