The one that prevents the HPOP reservoir from draining back into the oil pan when the engine is not running. Right now I forget the engineer's term for it, but it's around just below the bottom of the HPOP reservoir and part of the oil galley that feeds the HPOP reservoir. It may be part of the front cover casting, but don't quote me on that right now, LOL.
This would be my prime suspect as well. Like Dan, I forget the name right now, but will look around a minute.
That isn't really a check valve. It's called a short circuit valve. Even if oil was able to drain back via the lube oil pump, when the reservoir got oil again, ICP would climb and the engine should start.
If an upper injector oil o-ring is ruptured, it can allow oil to flow right out of the injector bore, through the oil return ports in the head and into the oil pan. It can also cause basically zero ICP while cranking, even though it's a relatively small leak path.
If a lower injector oil o-ring is ruptured, the oil would flow into the fuel system, you'd see a loss of oil on the dipstick and probably a black fuel filter element.
My IPR pigtail is coming later today, and I have the gauge/fittings to dead head the HPOP. That should tell me something.
Yup, it’s toast, I was afraid you’d see those flakes when you pulled it after seeing the reservoir was leaking down.
Interested to see the internals to see what happened.
