I'm going to say either a massive high pressure oil leak or a cratered pump. Even a bad IPR valve will build a couple hundred PSI cranking if everything else is OK.
That's a good point. Might be good to remove the valve covers and crank, looking for oil from under the injector solenoids, indicating an upper o-ring leak. Or pressurize each head with shop air and see what can be heard. Finally, an HPOP deadhead test could confirm whether it's building pressure or not.
If you contact CNC Fab, I expect they would help with diagnostic steps to confirm the HPOP, IPR, wiring etc since you’re running their pump.
Have you pulled the loom back to check the IPR and ICP wiring?
Maybe next step for me would be to apply direct power to the IPR (bypassing wire harness) to see if it builds pressure. I’d only do this briefly to keep from potentially hurting the IPR.
I’m sorry for your troubles Dan. You’ll get it back to 100% soon.
Typically the stage 2 hpop will still produce 150psi with an open ipr(at least on a deadhead test)
even hpop moving nothing, cranking should show 30psi of lpop pressure pushing though the system if ipr is actually closing as commanded.
Could be a leak, lpop issue, or a catastrophic hpop failure for some reason.
We’ll do some diag and figure it out
I'm not saying you're wrong, but the IPR is maybe 3 years old. Brand spanking new Motorcraft from RiffRaff.
The HPOP is relatively new, CNC Fab Stage 2...can these just straight up fail? I thought they get weak before they fail.
Originally Posted by Pikachu
I'm going to say either a massive high pressure oil leak or a cratered pump. Even a bad IPR valve will build a couple hundred PSI cranking if ever else is OK.
This is why I monitor IPR DC and ICP constantly on my ScanGauge. That rythmic rolling idle was your first clue that something in the HP oil circuit is going south. All four of my failed HPOPs (original bought with truck, two Adrenalins and one T500) showed the same symptoms as they failed. Some over the course of months, some within minutes.
I will check LPOP pressure via scantool later today.
Newp. The PCM isn't aware of base engine oil pressure. You'd need to add a pressure transducer or analog gauge. If the dash gauge comes alive, the pressure is at least 7 psi.
@FordTruckNoob@BWST@ESwift@Sous@z31freakify@JT250
I have gathered up various adapters to check LPOP and HPOP. When I removed the plug from the top of the reservoir to install a gauge to check LPOP....I find no oil in it.....at least not enough to get any on a long handle 3/16" hex wrench.....so down at least 2"
If I crank the starter for 10-15 seconds the gauge will come up to 40-42psi.
And now the oil level is within 1/2" of the top on the reservoir. I will check tomorrow morning and see where it's at.
The one that prevents the HPOP reservoir from draining back into the oil pan when the engine is not running. Right now I forget the engineer's term for it, but it's around just below the bottom of the HPOP reservoir and part of the oil galley that feeds the HPOP reservoir. It may be part of the front cover casting, but don't quote me on that right now, LOL.
