Computer Chips & Tuners
SuperChip Micro Tuner & system error codes
Old Dec 8, 2003 | 02:31 PM
Dwinn's Avatar
Dwinn
As I understand it, the SuperChip tuner will read the system error codes (hope I said that right). When you install the Superchip program or re-install the stock program for servicing, does this wipe out the existing codes or are the codes stored in a saparate module? What I getting at is... if you load the SuperChip program and then later on you have a fault/error code for the engine and need servicing, I would assume you would want to put back the stock program before going to the dealer. Would loading the stock program wipe out the error code?
Old Dec 8, 2003 | 02:37 PM
FTE Ken's Avatar
FTE Ken
No, you still need to hook it up and clear codes between program changes.
Old Dec 8, 2003 | 02:43 PM
Dwinn's Avatar
Dwinn
So each time you load the SuperChip program or the stock program you need to clear the error codes first?
Old Dec 8, 2003 | 02:49 PM
FTE Ken's Avatar
FTE Ken
No. But if you're taking it to the dealer its a good idea to clear the codes after returning the stock programming.
Old Dec 8, 2003 | 06:23 PM
Dwinn's Avatar
Dwinn
Thanks Ken. I appreciate your help and knowledge.
Old Dec 11, 2003 | 12:10 AM
FTE Ken's Avatar
FTE Ken
You're welcome.... I'm happy to help.
Sprocket1305
Apr 3, 2016 01:02 PM
oxt127
Mar 13, 2016 12:26 PM
GoneBrokeRacing
2004 - 2008 F150
Oct 8, 2015 07:31 AM
glockholiday
Apr 18, 2015 12:48 PM
StephenA
Feb 26, 2006 07:36 PM
