Hydronic coolant heater?
Old Jan 3, 2026 | 08:05 PM
  #121
wpg_250's Avatar
wpg_250
Originally Posted by kbeefy
It looks like yours is a 5A draw for a minute while firing up and then again while shutting down, less than an amp the rest of the time. Thats less than 2 amp hours for a 90 minute cycle.
Well I think my cheapo clamp meter wasn't giving me a reading in DC amps as it doesn't do DC from what I can tell. I think it was showing me voltage draw???
This is the unit I purchased:
https://www.princessauto.com/en/mini...HJhJZ3dWlPchJf
"Use to measure AC/DC voltage, AC current, resistance and continuity"
Guess I need to buy a better clamp meter that will do DC amps
Old Jan 3, 2026 | 08:58 PM
  #122
Baylinerchuck's Avatar
Baylinerchuck
It’s giving you a reading, but it’s an inaccurate reading…..who knows how far off. I wouldn’t trust a cheap-o clamp for measuring small current draw anyway. Something like that may be ok for measuring motor draws or branch circuit loads where 500mA or so either way isn’t a big deal.
Old Jan 3, 2026 | 10:06 PM
  #123
kbeefy's Avatar
kbeefy
https://www.princessauto.com/en/mini-digital-clamp-meter/product/PA0008344707?srsltid=AfmBOoqSvXTZxjPdNKOjiAmTRWURw 8a5f8ck3q6LMKHJhJZ3dWlPchJf
Ummm.... I don't think Voltage Draw means what you think it means. Actually, I don't think voltage draw is a real thing. Voltage drop is a thing, and it's measured with test leads, not a clamp meter.
The only thing a clamp meter can measure is current. It uses induction. I think your readings were pretty good. Amps are measured the same way in AC and DC, it's just the math thats different. Theres probably some semantics that are different.
Like I said before, the clamp meter you got isn't the best for very small loads. The field is too large. A shunt style ammeter (like the fuse buddy I posted, or similar) work much better for small loads. Or a smaller clamp meter, which are better but still not awesome.
Old Jan 3, 2026 | 10:29 PM
  #124
wpg_250's Avatar
wpg_250
Amazon Amazon
Would that unit be good? It's not the same model number as the one you posted so just checking before I order.
Thanks again 🙂
Old Jan 3, 2026 | 11:12 PM
  #125
TooManyToys.'s Avatar
TooManyToys.
The literature on it says AC current, not DC.
This would have been better:
Amazon Amazon
I have two of these for the smaller amps, but you don't want the expense.
Amazon Amazon
Old Jan 4, 2026 | 12:10 AM
  #126
kbeefy's Avatar
kbeefy
https://www.amazon.ca/Electronic-Spe...s%2C185&sr=8-1
Thanks again 🙂
That one only measures down to 1/10 of an amp. Not useful for parasitic draws.
The one I posted goes an extra decimal place (It was the 304B) so to 1/100 of an amp. It's not perfect for parasitic draw, but it's the best that fuse buddy does as far as I know and it is good enough for parasitic draw.
I'm pretty sure I went over all this stuff already.
I thought you sorted all this out already... what are you trying to figure out, exactly? I could make a better recommendation if I knew what you were after.
Old Jan 4, 2026 | 06:56 AM
  #127
wpg_250's Avatar
wpg_250
Well, mainly just trying to figure out how many amps my coolant heater pulls and yeah, I thought I had it figured out, but not sure if that clamp meter was giving me proper info as I don't believe it measured DC amps. So if I get that 304B fuse buddy I can fairly accurately measure the amp draw from my coolant heater and air heater AND I could use it to help me track down my parasitic draw so I'll order one of those instead of buying a more expensive clamp meter.
moloughlin
Apr 28, 2022 08:25 PM
TurboTuff
2004 - 2008 F150
Nov 9, 2021 10:17 AM
gross30
Dec 31, 2007 06:05 PM
sstipiotis
Feb 21, 2007 07:04 PM
2000psd
Dec 27, 2004 06:46 PM
