Bring back the rake
Old Oct 29, 2025 | 01:01 PM
BigBlack2020's Avatar
BigBlack2020
8th Gear
Bring back the rake
I bought my 2020 F-350 with a leveling kit already installed and 35's. It has the factory 2'' blocks in the back. I'd like to bring the rear end up just a little bit to even it out or even bring a little rake back to the stance.
Side thought: if I hit a bump on a turn the tires will rub my mudflaps. My leveling kit was a full spring kit, not just a spacer. How would you guys go about getting that up just a little more. I don't want to do a full lift because the height is nice where it's at, maybe just a 1/2" or 1'' would do.
Old Oct 29, 2025 | 01:55 PM
BPTS's Avatar
BPTS
Get the 4” blocks out of an earlier F250. ‘17-19 should still use them- I know my ‘20 didn’t.
Old Oct 29, 2025 | 02:06 PM
speakerfritz's Avatar
speakerfritz
add a 1" block to the rear or change the front springs or add a beefy air bag to the rear and pump them up to what ever you want.
Old Oct 29, 2025 | 08:08 PM
Southsounder's Avatar
Southsounder
You may want to consider take off rear blocks from a tremor. Depending on the source of information they are 3 inches or 3.25 inches or are the same as 17-19 rear blocks.
Old Oct 29, 2025 | 10:18 PM
Superdave71's Avatar
Superdave71
I put a 1”’block in on my 2020. I re-used the u bolts too. At the time I wasn’t sure if I’d be happy with only an inch so I held off on purchasing new u bolts.
Old Oct 31, 2025 | 03:08 PM
BigBlack2020
8th Gear
I'd prefer not to stack and I've already got bags in the back. Just looking to even it out a little. Might go with the Stryker 3" blocks and u-bolts.
Old Oct 31, 2025 | 03:37 PM
Jake from StateFarm's Avatar
Jake from StateFarm
Trailering
If you decide to purchase blocks, check out PMF if you haven’t already. They are a great option and you can choose how you want them (bump stop, no bump stop, or with platforms for mounting air bags in the future). Also, if you purchase new U-bolts you have the option to upgrade to 3/4” vs. the standard 5/8”. They are really heavy duty.
https://www.pmfsuspension.com/2017-2...cks_p_173.html
Old Oct 31, 2025 | 09:47 PM
BigBlack2020
8th Gear
these are sweet. If I go 3” do I need a taper? Mine is a short bed.
Old Nov 1, 2025 | 06:35 AM
speakerfritz
Be wary of blocks with loops around the ubolts. This is a marketing gimmick that serves no purpose. Blocks with loops for the ubolts are a PIA to install requiring removal of the ubolts .
Old Nov 1, 2025 | 07:48 AM
ibeb's Avatar
ibeb
When it comes to mild rub on a mudflap, if no adjustment was possible, I would always just find where the rub was and trim a little off the flap. Takes just a minute and the rub is almost always on the inside.
Old Nov 1, 2025 | 10:56 AM
BigBlack2020
8th Gear
found a part number on the coil spring. Looks like a readylift 2.5”. Number is 68-2250-01
still thinking I want 1 more inch in the front and then I’d need a 4” block. Thoughts?? Any other concerns I need to worry about?
Old Nov 1, 2025 | 06:28 PM
Jake from StateFarm
Trailering
I believe the 2.5 degree taper would work to keep the driveline angle correct. If you go PMF I would just give them a call to confirm.
Regarding the loops around the u-bolts, it can be a pain trying to get them straight enough to slide into the loops while working within the space under the wheel well. For the size you’re looking at it shouldn’t be an issue. With that said, you probably could more cost efficient options going another route than Stryker and PMF that would work just fine without loops.
No wrong answer with whatever option you decide on.
Old Nov 2, 2025 | 10:24 AM
BigBlack2020
8th Gear
I think I’m gonna get the Eibach 3.3 spring and a 4” block from Stryker.
springs:
https://eibach.com/eps-search?pf=PRO...4WD+%7C+Diesel
What length u bolts on the blocks??
Old Nov 3, 2025 | 09:23 AM
BigBlack2020
8th Gear
Looks like pro comp makes a 4'' block with taper that has the bump stops and u bolts for $149. Much more cost effective than the Stryker blocks. Probably going to go that route.
paintubturner
Jul 10, 2017 10:58 PM
russ2387
Nov 8, 2009 10:25 AM
Still Smoking
2004 - 2008 F150
Jun 27, 2008 05:04 AM
03PwrStk
Nov 23, 2007 10:35 AM
cdrmotorsports
Jun 11, 2007 07:58 PM
