Can blocks be used on front end for leveling kit????
Can blocks be purchased/made to act as a leveling kit for the front end? I have called 2 places that sell lift/leveling blocks but they both told me they are for the rear only. Now my Dad is telling me that putting blocks on the front isn't safe. If the u bolts are thru the blocks then it should be fine right??
Received 3,090 Likes
on
DO NOT USE "BLOCKS" to level the front end; not safe, period.
With that said, I have used both modified packs (extra leafs) and Zero rates from ORD and they work great; you could a touch longer shackle combine with tapered Zero rated but now were talking about some additional work. So, if this is your first time and you want to work on your truck what I'd do is a short add-a-leaf and a Zero rate..
cdrmotorsports
1999 to 2016 Super Duty
06-11-2007 07:58 PM
