2006 6.0l p0231
Old Nov 1, 2025 | 12:52 PM
  #31
cmartin's Avatar
cmartin
Trailering
Good morning. I ran the 12v directly to the hfcm by splicing in some clamps, truck starts now. Thank you all for the directions on troubleshooting. So....does this mean bad fuse box/unservicable relay? I see several used on ebay, please advise. Thank you all again.
Old Nov 1, 2025 | 01:44 PM
  #32
Hartwig's Avatar
Hartwig
They are not all the same. You must find one that fits with your truck / VIN.
And check fuel pressure.
Old Nov 14, 2025 | 07:33 PM
  #33
cmartin's Avatar
cmartin
Trailering
Ok, I received the rebuilt fuse panel a d got it installed tonight and it works. Thank you all for your input.
On a side note i have had an intermittent problem prior to this issue where i would get crank without a start, but it wouldnt even act like it was trying to start. It would just crank. When I scanned it I would get the crank position and cam position sensor errors but I read that was probably due to long cranking. I am curious if that same non serviceable relay could have caused that issue as it was beginning to fail?
Again, thank you all.
Old Nov 14, 2025 | 08:42 PM
  #34
bismic's Avatar
bismic
That is what happens with a bad fuel pump relay (it is integral to the CJB). The definition of a P0231 code.
Old Mar 8, 2026 | 01:47 PM
  #35
cmartin's Avatar
cmartin
Trailering
I replaced the CJB and , then bought a 2022 with low miles on it, and passed the 2006 truck to my son. After I replaced the fuse block, it started doing an intermittent no power. When i turned the key the injectors didnt wind up, and tje dash was blank. I would pull the cover to expose the fuse panel and slap the panel with my hand and then turn the key and it would get power. I checked all of the harness connectors at the back of the panel, they are seated. Is this a possible relay issue? Any thoughts on this would be greatly appreciated.
Old Mar 8, 2026 | 01:48 PM
  #36
cmartin's Avatar
cmartin
Trailering
Replacing the fuse block solved the fuel pump issue.
Old Mar 12, 2026 | 04:43 AM
  #37
TooManyToys.'s Avatar
TooManyToys.
Was that a used panel?
Old Mar 13, 2026 | 09:52 AM
  #38
bismic's Avatar
bismic
Hope he answers that question and provides some more detail. My impression was that it was a used and re-built CJB, but would also like to know where it was purchased.
Old Mar 13, 2026 | 05:33 PM
  #39
TooManyToys.
If used, he could have weak relay prongs, or the layout could be different. Those CBJs are not universal for all years and trims.
cmartin
Oct 28, 2025 09:52 AM
chriskowa2005
Bronco II
Apr 15, 2024 05:23 PM
lovemy150's
Jun 7, 2014 05:59 AM
JLMoreno911
1978 - 1996 Big Bronco
Aug 21, 2006 06:39 PM
96bronco58
Oct 27, 2003 05:15 PM
