Glow plug relay issue
Old Oct 25, 2025 | 01:49 PM
1993 IDI turbo's Avatar
1993 IDI turbo
1st Gear
Hello! New to the forum, hoping to get some help on my 1993 f250 7.3 turbo truck. Here is the issue.
bought the truck with a bad glow plug relay. Installed a new one, however I can not get it to work!
the guy before me used a button with one wire that I would touch to the back left terminal on the relay, and the other wire to the body to ground and it works great. However with the new relay hooked up properly, nothing.
any help would be appreciated
Old Oct 27, 2025 | 09:22 AM
knottyrope's Avatar
knottyrope
Do you have power to the push botton switch?
Did you clean the connections prior to assembly?
Old Oct 27, 2025 | 09:59 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Ohm out the ground wire or supply direct ground to controller. Check fuse K in the power distribution box. Check the fuse link, probably at the fender mounted starter solenoid.
Old Oct 30, 2025 | 07:06 PM
mattnj's Avatar
mattnj
Originally Posted by 1993 IDI turbo
...the guy before me used a button with one wire that I would touch to the back left terminal on the relay, and the other wire to the body to ground and it works great.
I don't quite understand this... Did you have to get under the hood to do these manipulations? Since you have turbo, your relay is on the fender, not all the way on the back under the air cleaner, but anyway...
Old Oct 30, 2025 | 10:31 PM
ihc1470's Avatar
ihc1470
I thought they were relocated to the right valve cover is it was a factory turbo. At least that is where it is on my 94.
Old Oct 31, 2025 | 07:07 AM
Olds64's Avatar
Olds64
Didn't the later 7.3l trucks use a relay & controller in one?
Old Oct 31, 2025 | 09:06 AM
WCMtn1990's Avatar
WCMtn1990
Yes, but a lot of people, myself included, switched to a manual GP setup. The white wire in that picture is removed and taped over. A new wire runs from a switch in the dash to take the place of that white wire and the switch is grounded to complete the circuit and activate the plugs. I suspect the OP has a problem with his ground or something simple like that. I recently upgrade to the monster White-Rodgers/Stancor glow plug relay, https://dieselorings.com/products/16...low-plug-relay
It's a big-*** relay.
Old Oct 31, 2025 | 10:21 AM
Olds64's Avatar
Olds64
I went to the White-Rodgers relay too. For a time I got the glow plugs on my 6.9l to work when I replaced the separate glow plug controller, but it quickly died. So, I went to manual glow plugs too.
murraycookies
Jul 12, 2020 05:20 PM
Dashriprock1977
84
Feb 1, 2017 08:41 PM
Ravenous Weasel
Jan 17, 2012 08:30 AM
meierw1
Oct 28, 2011 04:21 PM
dbrugger
Jan 6, 2009 07:32 PM
