Carb guru's needed
Old Oct 22, 2025 | 11:13 PM
whitey68's Avatar
whitey68
Carb guru's needed
So what I have is a 69 f100 360, it has one of them fancy shiny 2bbl carbs made by Shinn and foo you can buy off fleabay for 130 bux.
I bought a core correct to the year and engine and am rebuilding it with a kit from Mike's carbs, what I'm wondering is can i use the electric choke off of the 🥷 carb and use it on my 🇺🇸 carb
Truck has hedders so can't run the hot air set up.
Thanks man
Old Oct 23, 2025 | 06:37 AM
blue68f100's Avatar
blue68f100
Yes you can use the electric choke. Just need to run switched 12vdc power to it. I do that when I'm running headers or do away with the heat pipe.
Old Oct 26, 2025 | 06:58 PM
whitey68's Avatar
whitey68
***** Update *****
So I rebuilt the carb with the kit from Mike's carbs and took the electric choke off of the chineseium carb and put it on the oe carb.
It works!
so far so good. Having a little problem getting the timing dialed in but I believe I'm sneaking up on it. The dizzy is a gm style big cap electronic one with an adjustable vacuum advance.
I have the timing set at 12 degrees and vac adv turned out 5 turns.
The 360 runs strong, idle is good at 750/800 ish in park and feels just right in drive.
still going to tinker with it and will report back.
Jeff
Old Oct 27, 2025 | 10:33 PM
moto_hero's Avatar
moto_hero
What is your elevation that you mainly operate your vehicle at?
Old Oct 28, 2025 | 02:03 PM
whitey68's Avatar
whitey68
600' above
Old Oct 29, 2025 | 08:30 AM
carbking's Avatar
carbking
4wd Low
It works!
Jeff
If you are happy with the electric, great; but really quite easy to fabricate a heat stove to enable the use of the original hot air choke:
Heat stove fabrication
Since the heat choke is keyed to the engine temperature rather than a fixed time; it tends to give fewer issue.
Jon
Old Oct 29, 2025 | 04:26 PM
whitey68's Avatar
whitey68
Jon
Hi Jon
I was going to try and rig up some kind of hot air setup, my truck has a stock intake but has hedders.
knash0727
Jan 25, 2010 02:21 PM
oldfordman
Feb 18, 2005 04:17 AM
ford390gashog
Oct 5, 2004 07:41 PM
Titus Smith
Sep 17, 1999 04:14 PM
