Flooded Carburator when hot
Old Feb 16, 2005 | 06:18 AM
oldfordman's Avatar
oldfordman
Have an original 61 econoline with a 144 in it, and a 1 barrel Holley. Have had a problem with hot starting for quite some time. Basically, when it's hot, the carb is flooded. Tried rebuilding the carb, no help. Tried replacing the carb with a NOS unit, still same problem. Has anyone else experienced this?? More important, ahs anyone else solved this problem? Thanks
Old Feb 16, 2005 | 10:01 AM
jschira's Avatar
jschira
Are you still running your heater hoses through the carb base? You might wat to try bypassing the carb. This will help reduce the heat going to the carb.
Also, are you sure that when you push the choke handle in, the choke is actually all the way off? You may need to adjust the choke linkage.
Old Feb 17, 2005 | 09:08 PM
crecity678's Avatar
crecity678
is there a spacer between the carb and manifold
Old Feb 18, 2005 | 04:17 AM
oldfordman's Avatar
oldfordman
Thanks for the replies. I tried bypassing the carb base, no luck. There is no spacer between the carb and base, just gaskets. Should there be one of those thick spacers, and does anyone know where I can get one? Thanks again!
61 uni
Oct 13, 2012 08:42 PM
79F250inline
Feb 17, 2011 08:21 PM
bandit779
Aug 26, 2007 03:39 PM
crazeejames
Aug 27, 2003 12:37 AM
pfogle
Aug 25, 2003 04:46 PM
