460 fuel problem
Old Oct 20, 2025 | 03:51 PM
DannycP's Avatar
DannycP
Trailering
460 fuel problem
Hello, I got a 96 f250 7.5l that ive experience loss of power when accerlating, this only happens on the rear tank. Pulled the bed and replaced both pumps and noticed the rear been changed before. Still acts the same way and I followed the fuel line to see if maybe its kinked but im not seeing anything. To my understanding these gas engines doesn't have some selector mounted on the frame so im kind of a at a lost here since the front drives perfect. Any suggestions would be appreciated (fuel filter also replaced)
Old Oct 20, 2025 | 07:46 PM
06f35097f350's Avatar
06f35097f350
I just went through this with my 97 460, everyone recommends the Delphi fuel fuel pumps and I believe they are one of the better options, however, I got three Delhi fuel delivery modules in a row that were bad out of the box. Two of them the pump was low pressure and had same symptoms, the third had a faulty shuttle valve. The fourth worked as it should. I would definitely check your new fuel pump pressure under load with the pressure gauge taped to the windshield. Don't assume the pump is good because it is new. New parts are so bad anymore that it's a total crap shoot if they are good or not out of the box.
2fifty
Oct 7, 2025 05:28 AM
redfordpwr
Dec 31, 2023 04:24 PM
SoaDMTGguy
Nov 16, 2021 04:28 PM
Shawn Paris
Aug 2, 2016 10:56 PM
snowplowman
Nov 26, 2006 08:29 PM
