No Start
Old Oct 19, 2025 | 09:00 AM
La Low N SLow's Avatar
La Low N SLow
No Start
Hey folks. My 87 F-150 is not cranking. Put a new ECM on it yesterday hoping that was the issue, but it was not. I’m getting fire and it’s got 35-40 psi fuel pressure, but still want crank even with a little starter fluid.
Any idea on what to do next?
Thanks in advance.
Old Oct 19, 2025 | 01:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
will not turn over, or turn over but will not start?
Old Oct 19, 2025 | 02:29 PM
La Low N SLow
Yes Sir, I’ve checked the fuel pressure, 35 lbs, fuel pump is running, getting pulse on injectors, timing in about 8 degrees before top dead center. Checked the wiring order, 1-5-4-2-6-3-7-8. I am totally at a loss.
A little back story. About a month or so ago I cranked it up to go to my daughters. It cranked fine as usual and then it kinda sounded like a poof or a muffled pop, died and hasn’t cranked again.
Old Oct 19, 2025 | 05:58 PM
My4Fordtrucks's Avatar
My4Fordtrucks
You were asked if (a) the starter is turning the engine or (b) it is not turning the engine you said yes. Both is not an answer.
If the engine isn’t turning then how would fuel pressure matter?
Old Oct 19, 2025 | 08:38 PM
La Low N SLow
Let me clarify. The engine is turning over but will not start. Like I said, I have fuel pressure, fire and the timing is correct. The injectors are also pulsing. This has me quite confused.
Old Oct 20, 2025 | 08:20 AM
My4Fordtrucks
No air or one of those other things you said is good isn’t good. Do you have spark?
Old Oct 20, 2025 | 08:44 AM
La Low N SLow
Yes sir I have spark.
Old Oct 20, 2025 | 09:41 AM
wwhite's Avatar
wwhite
Compression test is next.
It is possible your exhaust is plugged.
Old Oct 20, 2025 | 12:31 PM
La Low N SLow
I will do that next, but 4 months ago I had new exhaust from the manifold to the rear. Just mufflers.
Old Oct 20, 2025 | 01:30 PM
wwhite's Avatar
wwhite
Flooded? hold your foot to the floor to clear.
Old Oct 20, 2025 | 04:03 PM
haveyouherdwithferd's Avatar
haveyouherdwithferd
At this point, might be worth trying starter fluid and seeing what happens.
Old Oct 20, 2025 | 04:14 PM
La Low N SLow
I have and didn’t even hit on that. I ain’t ever been not able to figure something like this out, but this one is kicking my butt!
Old Oct 20, 2025 | 06:02 PM
My4Fordtrucks
Then you do not have spark or air. I’m betting that air is not the issue.
Old Oct 20, 2025 | 09:18 PM
La Low N SLow
I definitely got spark. Pulled a couple of plugs and the spark great. I’ve got a mechanic coming tomorrow to re-run everything I’ve done. I’m absolutely at a total loss. Thanks
Cntryboy78
May 20, 2022 05:26 PM
mkbuth
Apr 15, 2018 03:06 PM
ruger761
May 19, 2010 10:32 PM
lavcheech
Jul 6, 2009 07:02 PM
KENCOEXT
Jan 13, 2004 08:08 AM
