460 fuel issues
Old Dec 30, 2023 | 02:31 PM
redfordpwr's Avatar
redfordpwr
1st Gear
460 fuel issues
I have a 97 f250 efi 460 having issues with midship tank. Fuel pump was recently replaced and I can hear the pump kick on when I turn the key to run position. Truck will start initially but will sputter and die in about 5 seconds after starting when front tank is selected. Truck runs fine when rear tank is selected. Any ideas on what could be causing this issue?
Old Dec 30, 2023 | 05:45 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The front pump. You need to put a fuel pressure gauge on it to see what is happening/ causing it to stall.
Old Dec 31, 2023 | 04:24 PM
Prototypemech's Avatar
Prototypemech
I agree. Put a fuel pressure gauge on it and see what the fuel pressure is doing. The big auto parts stores loan them out for free. It so easy to check the fuel pressure on these trucks, you could probably do it in their parking lot if they don't notice. Should take you 5 minutes.
sddaltongang
Jun 13, 2021 11:37 PM
Nsconyers
Dec 17, 2017 04:08 AM
mpmccarthy
Jan 5, 2006 05:57 AM
k460
Oct 20, 2005 06:00 PM
rick
Mar 3, 2000 06:16 AM
