Replacing AC Compressor
Old Oct 13, 2025 | 03:25 PM
TURDO's Avatar
TURDO
Good afternoon all.
I know this has been discussed but I can’t seem to make up my mind. Which replacement AC compressor is best? I am looking to replace the system on a 1997 7.3. I’ve heard good and bad about Denso and 4 Seasons. Seems I may be able to get the Motorcraft compressor but it is more expensive. Motorcraft part number I am seeing is YCC-193.
Thanks in advance.
Christian.
Old Oct 21, 2025 | 09:26 AM
Hit Man X's Avatar
Hit Man X
Both of those brands are good, GPD works okay...they all probably come from the same factory, just more expensive brands have better parts typically
Old Oct 21, 2025 | 07:28 PM
97-psd's Avatar
97-psd
Agreed. Either of those should be fine. Make sure you replace all the necessary stuff when replacing the compressor. A clean system is a happy system.
Old Oct 22, 2025 | 07:18 PM
TURDO's Avatar
TURDO
Thank you for the reply guys. Also do you know how much oil the system takes? I read it takes 7oz of PAG 46. The compressor came charged with 3 ounces of the PAG 46. Do I split the rest into the evaporator, drier and condenser? So 2 oz into the drier, 1 oz in the condenser, and 1 oz in the evaporator? Or am I overthinking it?
thanks again.
christian.
Old Oct 22, 2025 | 07:21 PM
TURDO's Avatar
TURDO
Also it is a whole new system. New lines, evaporator, condenser, compressor, drier and I’m replacing the orifice tube as well.
Old Oct 22, 2025 | 07:38 PM
Hit Man X's Avatar
Hit Man X
I mucho prefer PAO 68, read about it
38oz gas
Ford TSB states 11oz is charge for late trucks, so...
RED orifice, mind the direction.
Old Oct 22, 2025 | 08:54 PM
94F350_7.3's Avatar
94F350_7.3
Even though the compressor may state it has 3ozs, I always drain to verify. I can’t tell you how many have been off. I never trust what the sticker says. I have had good luck with 4 seasons, seem to be the better of the Chinese compressors.
Old Oct 22, 2025 | 09:43 PM
TURDO's Avatar
TURDO
Ok got it. So 11 ounces of oil total? Does it all go in the compressor or I need to divide it among all the ac parts?
Old Oct 23, 2025 | 07:14 AM
Hit Man X's Avatar
Hit Man X
I usually toss some in comp and the rest in the dryer.
Ford TSB was 11oz, up from 7oz
Old Oct 30, 2025 | 08:33 AM
TURDO's Avatar
TURDO
Hey guys another thing. I decided I’m going to flush the coolant while I have everything disconnected. House has well water and it does have iron in it. Can I still do the initial flush with well water and then follow it by flushing it twice with distilled water?
thanks.
Old Oct 30, 2025 | 11:10 AM
97-psd's Avatar
97-psd
Yes. An initial flush with it should be fine
Old Oct 30, 2025 | 11:23 AM
knottyrope's Avatar
knottyrope
pull bottom hose off before flushing as mine was lined with 1/2 inch of scale that the drain would never get rid of
Old Oct 31, 2025 | 07:51 AM
Hit Man X's Avatar
Hit Man X
Pulling the block heater also helps drain a pile.
Old Nov 9, 2025 | 02:19 PM
TURDO's Avatar
TURDO
Hey guys so I finally got around to charging the system. It is cold but I feel like it could be colder. Doesn’t seem to want to stay super cold at idle either at stop lights etc.
Maybe I need to add more Freon? I completely emptied 1 can but the other 2 cans I had seemed like they still had about half in them, but the system wasn’t taking anymore.
Gauge was reading 50 on the low side and about 250 on the high side while running.
Im in south Florida very hot and humid here which may also be a factor.
let me know.
thanks.
Old Nov 9, 2025 | 03:59 PM
farmert's Avatar
farmert
I'd say you are a little under charged. Low side should read around 40, high side should read around 275 depending on outside air temps.
tsmithco
Feb 13, 2023 05:49 AM
jake22si
1997 - 2003 F150
Jun 28, 2015 09:04 AM
wheelie31
Jun 20, 2010 10:36 PM
Psycho Sasquatch
Aug 31, 2007 11:55 AM
