AC compressor dead
Old Jul 7, 2022 | 03:32 PM
tsmithco's Avatar
tsmithco
AC compressor dead
Well, looks like it's my compressor. I'm going to attempt to replace myself tomorrow! AC lines are empty. Any tips and tricks from the group?
Wish me luck!
Old Jul 7, 2022 | 03:47 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Do you plan to recharge the system yourself or have a shop do it?
Old Jul 7, 2022 | 03:49 PM
tsmithco's Avatar
tsmithco
Shop will do it. I want it to be accurate. They quoted 1200 to do everything. $198 to recharge it I replace the comrpessor myself. so I'll save about 500 and learn something new in the process.
Old Jul 7, 2022 | 06:31 PM
4wd6.7L's Avatar
4wd6.7L
Did it seize up? When mine went out(seized) they replaced more than just the compressor. They flushed the lines or something to make sure all debris was out, replaced compressor, condenser and expansion valve.
Old Jul 7, 2022 | 06:42 PM
tsmithco's Avatar
tsmithco
Doesn’t seem like it. Just not engaging. Prob could just replace the clutch, but might as well replace the whole compressor.
they did a flush out and he pulled vacuum. Said no signs of anything that shouldn’t be in the lines.
Old Jul 7, 2022 | 08:12 PM
elee3's Avatar
elee3
When you have no Freon in the system, the compressor clutch won’t engage unless you override the low pressure switch. You might just have a leak.
Old Jul 7, 2022 | 08:13 PM
tsmithco's Avatar
tsmithco
Yeah. Was low but not too low. He refilled afterwards and still no compressor engaging.
Old Jul 7, 2022 | 08:24 PM
elee3's Avatar
elee3
Did he short the low pressure switch?
Old Feb 12, 2023 | 04:03 PM
sgrol's Avatar
sgrol
TSmith - How did this turn out?
Old Feb 12, 2023 | 04:05 PM
tsmithco's Avatar
tsmithco
turns out the ground wire had frayed and broken inside the main wiring harness. The intermittent connections apparently eventually also fried the clutch. New compressor installed and new ground ran.
Old Feb 13, 2023 | 05:49 AM
4wheelsandahitch's Avatar
4wheelsandahitch
This sounds like it could happen in many cases. Do you know where the broken place in the wiring harness is?
Krapfl
Aerostar
Sep 6, 2019 06:40 PM
jake22si
1997 - 2003 F150
Jun 28, 2015 09:04 AM
run6.0run
Oct 20, 2013 03:43 PM
wheelie31
Jun 20, 2010 10:36 PM
