Bronco II Ford Bronco II
Gear ratio
Old Oct 12, 2025 | 04:56 PM
Wheelsworld58's Avatar
Wheelsworld58
4th Gear
Gear ratio
I have a 1990 B2 and have rebuilt the motor bored 30 over added a mild cam, ported heads and intake, added headers my compression ratio is 10.5 to 1 so now my question is should I go with 3.45 ratio gears or 3.27 gears for I am going to use the truck to cruise and for road trips. The truck has cruise control and I am thinking it would be better to go with the 3.45 so I don't have to down shift for long hills. Any thoughts on this. Thanks.
Old Oct 12, 2025 | 05:01 PM
85e150's Avatar
85e150
What tire are you running? Probably stick with 3.45s.
Old Oct 12, 2025 | 05:13 PM
Wheelsworld58
4th Gear
I have 235/70r/15 but I am going to change to 265/75r/15. My size, Dia. is to go to a 29 diameter.
Old Oct 12, 2025 | 06:37 PM
85e150's Avatar
85e150
3.45s at least.
Old Oct 13, 2025 | 12:07 PM
Wheelsworld58
4th Gear
Smile
Thanks for the advice, I was leaning towards the 3.27 ratio at first but then thought the rpm would be to low in the torque range and the 3.45 would be a better choice for what I'm going to use the truck for.
Cb2004
53
Mar 10, 2025 07:10 AM
stbart
16
Aug 19, 2022 06:59 AM
Joe Meg
6.7L Power Stroke Diesel
Jan 18, 2010 05:35 PM
j6jones
2004 - 2008 F150
13
Nov 19, 2008 10:53 AM
1955effie
20
Mar 30, 2008 01:26 AM
