Front Fairing Super Duty
Old Oct 18, 2025 | 09:22 AM
Midwest87's Avatar
Midwest87
Masking tape and Bosche reciprocating saw.
Cut mine to my liking. About 2" left maybe. Truck looks way better. People dont even realize why sometimes, since it still looks factory.
Old Oct 19, 2025 | 11:45 AM
6.2caribou's Avatar
6.2caribou
My '17 sat at least 2" higher than my '25 does and I snagged it more than once on snow banks and high curbs. When the '25 came in, a new 2wd valance was one of the 1st modifications that I made. I just couldn't convince myself that cutting the 4wd valance would look as good as the 2wd version, which I picked up on eBay for a very reasonable price.
Old Oct 19, 2025 | 05:14 PM
zeroo's Avatar
zeroo
Originally Posted by NevadaMike
Is there a reason to put a smaller fairing over just removing it and going naked?
there is no mpg gain, i have a thread here about it, i drive up to 200 miles a day and did mpg with both, the 2wd and 4wd..and you cant just go naked, it finishes off the bottom of bumper.
Old Oct 19, 2025 | 05:16 PM
zeroo's Avatar
zeroo
I used to buy the 2wd valance but this 2024 truck i just marked it and cut it with a razor knife. If you’re handy and strong it’s super easy. If you work in a cubicle it may pay to buy one. Or, you could use a saw i guess…
Old Oct 21, 2025 | 12:08 PM
acdii's Avatar
acdii
Its that way for aerodynamics and cooling. Ford does extensive wind tunnel testing and makes them this way for a reason. We may never see the actual reason for it being so big, but Ford did. Maybe to reduce the amount of drag under the truck by directing the most mass around the side? If you look closer at the bumper and headlights, there are small ducts leading to other areas of the truck, like for moving air around the tire instead of air hitting it head on.
I would say these are more likely carry ups from the F150 trucks because those have to meet CAFE and EPA standards, but the SD trucks don't so we won't see a difference removing the baffle, but the F150 would. Mine has hit quite a few things and the bottom edge is a bit scuffed. It does hang down too low, at least on the other trucks I could crawl under the front bumper, not on this one.
Old Oct 21, 2025 | 12:55 PM
zeroo's Avatar
zeroo
maybe they should spend more time testing ac compressors than worrying about a snow plow on these things.
Old Oct 21, 2025 | 01:29 PM
NevadaMike's Avatar
NevadaMike
Does anyone remember what size of wrench or socket is needed for the fairing and Prius catchers?
Old Oct 22, 2025 | 05:36 PM
HeatStroked's Avatar
HeatStroked
10mm?
Old Oct 22, 2025 | 06:51 PM
maxGasser's Avatar
maxGasser
The small bolts for the air dam are 8mm or 5/16”
The big nuts on the Prius catchers are 18mm or 3/4”
Old Oct 23, 2025 | 06:37 AM
NevadaMike's Avatar
NevadaMike
Thanks
Old Oct 23, 2025 | 10:34 AM
CBEllis's Avatar
CBEllis
So, because of the truck height, they sacrifice aerodynamics and cooling on either the 2WD's or the Tremors that have the shorter chin spoiler? I guess it's a projected mix based on their sales and the gov't regs that they need to meet overall, but I don't see this making any noticeable difference in the real world. Maybe in a wind tunnel, sure, but not on the road where conditions are always variable.
Old Oct 23, 2025 | 11:53 AM
roadpilot's Avatar
roadpilot
Originally Posted by wcbcruzer
There's also a Tremor valence that is even smaller than the 2wd one. I'll see if I can find the part number.
A friend of mine replaced the one on his '24 F250 Lariat with the one for the Tremor. Sorry, I don't have the P/N.
Before and after photos.
Old Oct 24, 2025 | 10:44 AM
  #28
acdii's Avatar
acdii
Cooling is the same on all of them, the airdam as you can see in the pics below is for aerodynamics. The Tremor is that way because of what its is designed for, Off Roading. But if you look at the two you can see how the airdam blocks the tires, that right there is the aerodynamics. It forces the air around them because the spinning tires at highway speeds creates drag when air hits it at like 60 MPH, this helps prevent that. It could mean as much as .5 MPG, but our trucks vary so much in the FE territory, its hard to actually verify. Like I said, these are carryovers from the F150 where they really do make a difference.
Old Oct 24, 2025 | 10:49 AM
  #29
wirelessengineer's Avatar
wirelessengineer
You are probably right about the carry up. We all need to keep in mind that many things the manufacturers do is NOT because it's better in the real world, but because they are trying to meet CAFE standards.
Old Oct 24, 2025 | 01:31 PM
  #30
wcbcruzer's Avatar
wcbcruzer
I actually like the large front air dam. Makes the truck look more modern imo. If truck was lifted that would change tho.
