key turn does nothing
Old Oct 12, 2025 | 08:38 AM
mscham's Avatar
mscham
Angry key turn does nothing
trying to be brief but informative
  • had no dash lights
  • took dash apart
  • replaced illum light bulbs in instrument cluster
  • put it back together
  • still no dash lights
  • more reading seemed to indicate could be caused by bad headlight switch
  • disconnect headlight switch from dash
  • pull switch out of dash
  • while attempting to remove switch from connector I can see a little movement
  • disconnect batteries
  • use screw driver to gently pry switch from connector...
  • eventually separate switch from connector
  • don't see anything wrong with connector so order replacement headlight switch
  • put everything back together
  • connect batteries
  • turn key: NADA, absolutely nothing happens
I now have a 9000 lb paper weight.
  • I don't have warning chime with key in ignition and driver door open
  • I have checked all fuses
  • I have confirmed my batteries have charge
It seems something happened while I putzed with headlight switch and its connector with power.
Thoughts on what that could be?
Old Oct 13, 2025 | 06:37 AM
tjc transport's Avatar
tjc transport
i ain't rite
first thing i would check is batteries and connections.
Old Oct 13, 2025 | 05:03 PM
paddler's Avatar
paddler
Headlight switch & circuit is separate from key switch. That NEITHER does anything means either you have a hard failure in BOTH switches or wire or connection problems common to both.
Battery connections, both positive and negative, are a good place to check.
If you have a test light or volt meter, the first thing I would check is for 12 v between several chassis ground points and battery positive. If ground/negative to batteries is bad, checking circuits for +12v to the fuse box feeds or switches without the other end being battery negative terminal will give you a false result. After confirming negative/ground is OK, then you can start checking for +12v between major positive feeds and a convenient ground.
If putzing with headlight switch "blew" all power to the truck, you should have noticed a VERY energetic event. I'm with Tom; either batteries dead or something in the big battery cables and connections are most likely.
CueMan's 78 F-150
Apr 24, 2012 02:52 PM
ceo
Jan 4, 2007 10:45 AM
franco99
1978 - 1996 Big Bronco
Feb 8, 2006 03:25 AM
brokenoldford
Electrical Systems/Wiring
Dec 29, 2004 05:29 PM
GWB
Aug 29, 2003 06:42 PM
