Bed step lights help
I bought parts to make my own harness. The metal pieces you crimp down were a PITA until i got the right pliers. See the part in the tool, this worked perfectly
Tried these out. Worked well. Just strip a little wire back, jam it in both ends lol, then with a heat gun just slowly turn it to evenlt heat and the solder melts and the colored part also seals it and it shrinks.
You get the idea here. I went back and heated a little more to seal it better.
