first post so take it easy. is there a way to turn on the bed lights while driving. I've gotten my tow mirror spot lights to stay on with a jumper between pins. im looking for a solution like that. I also have forscan if there's a solution with that. Thanks
Hey, that's a good one...welcome to the fold
I'll keep an eye on this
I dont believe theres a way to do this. I would have to look at the wiring diagrams to see how they are wired in but I believe they cut off as soon as the vehicle is above a set speed. youll have to rewire to make this possible.
Yea I was hoping to find something in forscan that disables whatever let’s it know your driving. Im
going to wire lights into the harness for the electric running boards and those would come on with the cargo lights and bed lights as well. Thanks again I’ve combed the inter webs and can only find solutions if they don’t shut off but nothing that says keep them on. I’m not opposed to rewiring either. I attempted to tie into the bed switch once so my small light bar/work light came on with the bed lights but that was no good. Learned there’s no fuse it’s all on the puter
Rear facing lights that are not red or amber while driving forward are illegal in many jurisdictions so be careful about running with your cargo lights on. It might bring you some unwanted attention.
Originally Posted by insaneCreations
Reverse lights are not red or amber and are legal...
You're also not driving forward when reverse lights are on ?
Do you mean the optional in-bed cargo lights or the high back of cab lights? The in-bed lights would pose less legal problems and might be easier to rewire.
“For off-road use only “but thanks for the helpful question…
No need for snark when you're the one with poor reading comprehension.
I am still trying to figure out why someone would want the cargo lights on while underway. The best I can come up with is maybe some people think it looks cool?
Check out Ford Super Duty Mirror Spot Speed Override Harness – Limitless Autoworks LLCThis simple plug and play harness will give your 2017-2022 Super Duty or 2015-2020 F-150 mirror spotlights the ability to come on and stay on whenever the factory button is pressed. Originally these lights turn off when driving over 6mph.
I guess you never had gear shift in the bed of your truck while “driving forward” and wanted to illuminate the area to check the cargo. Mind blowing I know.
