Rear door window replacement.
Old Sep 28, 2025 | 10:59 AM
F0rdc0wb0y's Avatar
F0rdc0wb0y
On vacation this past week and the rear driver side window glass separated from window regulator assembly. Somehow in the process of trying to go back up with the window, it bent one side of the assembly. I took the door apart and hammered and pried the assembly back straight enough to get the window rolled back up. Already ordered a new fomoco window regulator assembly.
On the actual glass itself there are two clips that are glued to the bottom of the glass at each end. Those clips then bolt into the regulator assembly, and your window rolls up and down. On my truck, the adhesive failed on those two clips, separating the glass from the regulator assembly. Clips are still bolted to the regulator assembly but are not glued to the glass. If the window is not fully rolled up, I can literally grab the glass and manually pull it up and down. My question, can I buy these clips, or do I have to buy entirely new glass? One of my original clips is pretty bent. You can see the clips in this pic.
Old Sep 28, 2025 | 05:45 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
There are
plastic generics on Amazoo plastic generics on Amazoo
that might work. Cheap enough to try.
Did not see anything OEM from Ford but I only tried that one place.
I'd consider a junkyard part too.
Old Sep 28, 2025 | 07:09 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Any chance on using window installation adhesive or similar to affix the brackets to the window? Depending on the bent one still being serviceable.
Just the other day I was researching regulator and window run as my driver side is starting to show its age by going up slow.
Old Sep 29, 2025 | 11:07 AM
Eman85's Avatar
Eman85
I've always just epoxied Ford window channels back on the glass, last on I did was a Saleen Mustang.
Old Sep 29, 2025 | 02:46 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
I’m going to swing by Safelite today. I have a rock chip in the windshield I need to have looked at. I’ll ask about those window channels. If they don’t have anything I’ll prolly give the ones off Amazon a try
tellico racing
1947 and Older Ford Trucks
Jan 4, 2025 06:32 PM
dw8
Nov 1, 2021 09:59 AM
eaglestone
Jun 20, 2010 10:03 PM
Thunderduckie
Nov 6, 2009 12:52 AM
nflfreak43
Jan 24, 2009 02:17 PM
