Running hot after idling
Old Sep 23, 2025 | 08:22 AM
bigbo62's Avatar
bigbo62
6th Gear
I have a 95 F-150 with the 302. I just rebuild the engine and I'm almost done breaking it in but I've ran into a small issue. After idling the truck for 15 or so minutes the gauge reads about at the "L" normal. When driving it read between the "N" and "O". I made sure to bleed the system by running the truck with the rad cap off and turning the heater on. I know these gauges are not the most accurate but I was just wondering if this was normal.
Old Sep 23, 2025 | 08:33 AM
jas88's Avatar
jas88
No, not normal. First thing I would do is test the accuracy of your gauge with a temp gun on the thermostat housing. If indeed it is running that hot idling, then you are not getting enough air thru the radiator via the fan. Check your fan clutch.
Old Sep 23, 2025 | 10:37 AM
bigbo62's Avatar
bigbo62
6th Gear
Alright, I'll pick up a temp gun today and test it. How would I check the fan clutch?
Old Sep 23, 2025 | 11:36 AM
Junktownbill99's Avatar
Junktownbill99
Spin it by hand, if there's no drag, it doesn't work. It should also howl when the engine gets hot.
Old Sep 23, 2025 | 04:32 PM
Mr.Lars's Avatar
Mr.Lars
What condition is the fan shroud?
Does the alternator charge level drastically change at idle vs road speeds?
Old Sep 23, 2025 | 05:16 PM
bigbo62's Avatar
bigbo62
6th Gear
I just use the temp gun and at about the O on the gauge it was 195, and at about the L it was at 230. I also spun the fan and there was resistance and it would stop spinning once I let go.
Old Sep 23, 2025 | 06:09 PM
bigbo62's Avatar
bigbo62
6th Gear
Never mind, forget everything I've said I've solved it. Some genius (me) set the timing at 20 so now I just set it to around 10, so I think I'm good now.
Old Sep 24, 2025 | 06:58 AM
rla2005's Avatar
rla2005
Assume you removed the SPOUT plug to set the base timing?
JimmyJames707
49
Aug 20, 2022 03:31 PM
Tim 79 F150
May 10, 2014 02:52 PM
coolguy1419
17
Apr 10, 2010 01:06 PM
BTW
Jun 5, 2008 09:54 PM
