79 302 auto running too hot
Old May 10, 2014 | 11:34 AM
Tim 79 F150's Avatar
Tim 79 F150
Last summer my truck was running hot based on the reading of the Temp gauge. If I turned on the cab heater it would drop back to the normal reading it had.
This spring I had the rad re-cored, there was a lot of white crap on the tubes looking down into the rad. I replaced the 192 F thermostat with the same rating stat.
First ride and after a little running settled down where it has always run based on the Temp gauge. Then after running for 10 min at 60 mph it started to climb in reading on the gauge. Turning on the cab heater did nothing to drop the temperature. It did not drop back to normal during the rest of the ride even with the cab heater on.
Outside air temperature was 55 F
Thanks for any ideas
79 2 WD LWB Auto Ps PB 302 F150 50,000 miles new re-core 3 row rad new 192 thermostat
Old May 10, 2014 | 11:42 AM
HIO Silver's Avatar
HIO Silver
If referring to the factory guessing gauge, its reading isn't really useful. I recommend installing an aftermarket gauge with numerical graduations so it provides the actual temperature rather than the Kentucky windage.
Add a bottle of Redline Water Wetter or Royal Purple's "Purple Ice"; and,
Did ya flush the heater core?
Old May 10, 2014 | 12:48 PM
Tim 79 F150
Thanks for the reply, I will get the recommended product. The heater has not been flushed but I get a ton of heat in the cab. What do you think about getting a complete cooling system flush?
Old May 10, 2014 | 02:52 PM
dying breed racing's Avatar
dying breed racing
That almost sounds like a water pump. I would replace it before doing much more. If that doesn't fix it then flush the entire system good. Also I know some of the 70s era engines had a bypass thermostat to keep coolant circulating and not letting the back of the block and heads get to hot but the replacements don't have the bypass. I have drilled a small hole in the flat of the thermostat and they stay cool but keep temp. But I could be thinking about the 335 series.
Robertsma2
1978 - 1996 Big Bronco
May 11, 2017 10:48 AM
burntice
Mar 16, 2012 08:47 AM
berry1234
Mar 26, 2009 09:57 PM
v8xploder
Dec 28, 2007 05:01 PM
rguy
Jan 26, 2007 10:28 AM
