Intake plenum coolant o ring
Old Oct 1, 2025 | 08:12 PM
joe blow's Avatar
joe blow
I am just hoping they changed it to a longer lasting material.
Old Oct 11, 2025 | 08:11 AM
joe blow's Avatar
joe blow
Got it all apart yesterday......man I forgot how much I hate top end work on this truck due to its height and just all around PITA
The o-dawg manifold, along with the BPD oil lines draped across the top would have made it next to impossible to take a short cut.
The plenum o-ring was split down the center. Most I've seen are compressed and leak, but this had a split down the center and I can't believe it only leaked as little as it was.
As mentioned in other posts regarding the BD up pipes and bellows I installed that was rubbing on the firewall stud for the coolant pipe, that is getting addressed as well along with replacing the firewall pipe that leaked after only 8 years (SMH).
Since it is out, I am able to swap the egr cooler o-ring that BTW is the same part number as the o-ring used in the coolant heater pipe.
Anyway have a long day ahead of me.....did I mention I hate this?
Old Oct 11, 2025 | 06:33 PM
joe blow's Avatar
joe blow
I started a turbo vane thread with some updates. I truly hope this is the last time I have to do this.....for now
Old Oct 12, 2025 | 02:13 PM
joe blow's Avatar
joe blow
Done and no more leaks.....for now
The most important part is I was able to fix the BD up-pipe issue I didn't catch on install earlier this year. It drove me crazy seeing soot in the engine bay because the bellows never mated into the turbine housing with that positive click. I wrapped all pieces with titanium wrap and added a turbo blanket I had in a box for 10 yrs. Needless to say with all that extra stuff in sight, it concealed the stud contact.
I should be good to go until the next thing this girl throws at me,
Old Oct 12, 2025 | 06:13 PM
wpg_250's Avatar
wpg_250
That "doughnut" o-ring is such a lazy and stupid design imho!
The underneath end of the manifold should have had V taper that slid into a 3/4'' round silicone or high end rubber gasket that sits where the doughnut O-ring sits to make it a beefier and longer lasting seal.
Something like this:
Old Oct 12, 2025 | 07:00 PM
joe blow's Avatar
joe blow
The crap part is you are forced to take the whole top half off to replace it.
I understand there are shortcuts, but I've always been the guy that thinks shortcuts are a recipe for re-work.
No way in hell I was going to do all this and end up with a leak.
Oh well, a few days of work and it is good to go for another 5+ years or more.
Old Oct 12, 2025 | 10:51 PM
wpg_250's Avatar
wpg_250
I was lucky enough to get away with just loosening all the intake bolts to give enough clearance to remove the old one and slide the new one in. I did mine outside in -10c temps so I went with the faster route, but if it was summer I'd have taken the whole thing apart.
Old Oct 13, 2025 | 12:07 AM
Fuzzpuss's Avatar
Fuzzpuss
If anyone has the part number, please post it here for future reference. I don't need it anymore, but I've never been able to find it and that always bugged the hell out of me.
Old Oct 13, 2025 | 02:19 AM
bismic's Avatar
bismic
EGR cooler, not the intake donut: 3C3Z-9J469-AA
Full size assembly image of EGR COOLER, VALVE & RELATED PARTS 8 CYL. 6.0L - DIESEL. (1/1)
https://parts.universalford.com/a/Fo...EL/P40760.html
https://parts.universalford.com/p/Fo...-9J469-AA.html
Old Oct 13, 2025 | 06:49 AM
joe blow's Avatar
joe blow
The new plenum o-ring is now orange and not black (just an fyi).
I am hoping they upgraded the material
Old Oct 13, 2025 | 07:57 AM
wpg_250's Avatar
wpg_250
It's still a lazy design regardless.
Old Oct 13, 2025 | 09:49 AM
Fuzzpuss's Avatar
Fuzzpuss
Originally Posted by bismic
That's the part, but is it the same for the early coolers?
The product page says it's for 05-07. The diagram shows an 03-04 intake elbow with the newer cooler and intake manifold. Or was this common configuration for the later 04's and/or early 05's?
That website is a great resource!
Old Oct 13, 2025 | 11:03 AM
  #28
bismic's Avatar
bismic
I am not aware of any changes in that specific port across model years.
  #29
TooManyToys.'s Avatar
TooManyToys.
Using a taper along with compression would stress the O-ring more than it is, due to compression and expansion. I'm fine with it as it is.
Old Oct 13, 2025 | 03:19 PM
  #30
joe blow's Avatar
joe blow
Mine lasted 8 years. As mentioned I was surprised it was not gushing out because the o-ring was literally split in half toward the front.
Under compression I am certain the gap was much smaller but nevertheless, it was barely leaking and none that I could see at operating temps.
wtroger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 10, 2021 11:47 PM
7.3stroker2
Feb 4, 2016 04:28 PM
khxor
Feb 5, 2011 02:00 PM
mtflat
Apr 5, 2005 01:28 PM
B2low
Bronco II
May 10, 2004 01:03 PM
