Combo question...
Old Jan 16, 2007 | 04:13 PM
Jrock909's Avatar
Jrock909
Combo question...
Guys how many of you in here are running the 1.7 ratio rockers and 302HO cam combo and how do you like it?
Thanks,
Jason
Old Jan 17, 2007 | 09:51 AM
P51D Mustang's Avatar
P51D Mustang
I ran 1.7's with the HO cam about ten years ago. I noticed a nice increase in midrange tourqe. It also had a nice wide power band.
Old Jan 17, 2007 | 03:47 PM
Jrock909's Avatar
Jrock909
P-51 did you have to replace the valve covers because of the 1.7 rockers hitting the baffles though? It really does suck that I might have to replace the covers because of that issue.. ;(
Thanks
Old Jan 17, 2007 | 06:38 PM
ken75ranger's Avatar
ken75ranger
I run the stock '87 ho cam and 1.7 pedestal rockers with a carb setup..Great combo. Good off idle power. I tried the E-cam with them and it wouldn't idle below 1000 rpm. The problem was my auto tranny. When you put it in gear and hold the brake it would stall if I went lower on the idle. It ran like a wild horse from 2500-5500 rpms. I just couldn't get there easily with my gears and tires. I needed new valve covers anyway so I went with the taller ones.
I have heard you might be able to fit them under the normal valve covers if you do some grinding to the baffles. Personally I'd go to a taller valve cover. Are you running a car upper intake? If you do you can get an intake spacer to gain the height you need.
If you do some searching on one of the mustang forums I'm sure they could tell you the easiest way.
Old Jan 17, 2007 | 09:56 PM
Jrock909's Avatar
Jrock909
Ken I am currently running the 302EFI truck upper intake so I don't know what I am going to do as of right now, but I do know something this install is not going to happen for awhile now since all the bad weather has hit us... 4 inches of solid ice on the ground it's crazy. Canadian weather in KS is crazy, it's like the day after tommorow right from the movie. If I run taller valve covers I will need a intake spacer correct? Another note what exact valve covers can I run with on my 302EFI truck being that I have the screw in type oil cap and the PCV valve on the passenger side?
Thanks,
Jason
Old Jan 18, 2007 | 09:50 AM
P51D Mustang
Thanks
No, I didn't, but they were the finned 85 HO covers, not the EFI cover.
Crash F250
Jun 4, 2016 11:06 AM
turnkyle
Mar 28, 2015 10:44 AM
Amelio
Jan 25, 2013 05:10 PM
motopsyko32
Jul 6, 2010 04:50 PM
docinabox
1997 - 2003 F150
Jul 3, 2003 08:53 AM
