Stumbles on startup?
Old Sep 20, 2025 | 11:19 AM
mbooth576's Avatar
mbooth576
4wd High
I have a 1990 f150 with the 4.9L straight 6. When the truck is cold, like the first start in the morning, the engine stumbles and will die unless I quickly press the gas. Anyone have any ideas to what could cause this? Only recently started happening now that it's getting cooler outside
Old Sep 20, 2025 | 01:54 PM
jas88's Avatar
jas88
Clean IAC valve first.
Old Sep 26, 2025 | 01:13 PM
mbooth576's Avatar
mbooth576
4wd High
Cleaned
cleaned iac valve and changed gasket but didint seem to fix the issue
Old Sep 26, 2025 | 01:17 PM
jas88's Avatar
jas88
Did you reset the computer after?
Old Sep 26, 2025 | 01:18 PM
mbooth576's Avatar
mbooth576
4wd High
No.. didn't think about it. Do I just unhook the battery for a few or do I have to do something to reset it?
Old Sep 26, 2025 | 02:03 PM
88n94's Avatar
88n94
They say to unhook the negative battery cable for atleast 10 minutes.
Old Oct 11, 2025 | 03:37 PM
mbooth576's Avatar
mbooth576
4wd High
ok, been a while but have some updates. After cleaning iac and replacing gasket, as well as resetting the ecm and driving it at least 20 miles for the ecm to recalibrate, the problem is still there. It only happens every like 1 in 3 cold starts. Any other ideas?
Old Oct 12, 2025 | 03:14 AM
AuroraGirl's Avatar
AuroraGirl
leaky injectors or fuel pressure regulator problems. also could be vacuum leaks and egr related or canp related
Old Oct 12, 2025 | 07:37 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I don’t have any luck cleaning the IAC. Are there KOEO fault codes?
Old Oct 13, 2025 | 10:12 AM
mbooth576's Avatar
mbooth576
4wd High
nope, no codes at all. Also, truck idles and runs fine after it starts just has an issue when starting
Old Oct 13, 2025 | 10:34 AM
AuroraGirl's Avatar
AuroraGirl
Old Oct 13, 2025 | 11:50 AM
My4Fordtrucks
Not even the system pass code 11/111?
MiamiPSD
Dec 22, 2020 04:20 PM
77-250
Aug 2, 2011 11:38 PM
SHAWN056.0
Sep 13, 2010 09:33 PM
selmacpa
Feb 5, 2008 06:12 PM
tomtoc
Sep 17, 2007 08:26 PM
