Need help with 6.2 liter
I need to help my son who is broken down in Rawlins, WY pulling an RV.
He has a 2020 with the 6.2 liter, he was going up a hill and it started to misfire. He pulled over and it initially wouldn't restart on the third attempt it restarted but was running poorly. We pulled into a Walmart and upon looking under the hood he noticed a coil arching to the block, he replaced the coil but it was still running poorly and had fuel pouring out the exhaust. He scanned it and it come up with a code for the injector on cylinder 3. He has now replaced that injector and it seems to be running better, but there is still fuel pouring out the exhaust. I had him face time me so I could see and there is quite a bit of fuel coming out the exhaust.
He cleared the codes after replacing the injector and none have come back, any ideas on what it could be?
Gas would have evaporated or got caught up in the cats and burned off, never would have made it as liquid clear out the end of the exhaust system.
Modern engines put out alot of water out exhaust. Really really uncommon for port combustion injectors to fail..
How many miles/hours?
Did he actually detect a misfire with scanner?
Can you describe the "running poorly" what was it doing?
OP, sounds like the kid is up a creek, he needs to find a shop to take a look at this truck, or get it towed home if he has the tools at home. This is unlikely to be a 'quick fix' in a Walmart parking lot.
Thanks for the responses, the truck has 144,000 miles.
He is going to get it towed to the Ford dealer today
rainman35
Jan 25, 2013 11:16 AM
