TTB lift
Old Sep 4, 2025 | 06:58 PM
1994F150351w's Avatar
1994F150351w
4wd Low
TTB lift
Can I put a RSK on a 44HD TTB front axle? I’ve heard mixed opinions on it, and I’d love to improve the ride quality, as well as add some lift to it. I’ve already got add a leafs, not sure if that would change some things. I know with the already added 2” of lift I’ll need a new pitman arm, shocks, 4” drop brackets and probably extended brake lines too.
Old Sep 5, 2025 | 06:55 AM
Franklin2's Avatar
Franklin2
As long as you lift everything with it, you can do it. The shackle reversal kits are only made for the straight axle trucks because they do not use the pivot brackets in the center. But as long as you get the drop center brackets, you should be ok, along with the longer shocks, dropped pitman arm, relocated or longer brake lines, etc.
Those lift springs are ruining your ride. If you get rid of those, it will help the ride tremendously.
1989bricknose
Mar 19, 2017 12:37 PM
ford_mudd_runner
Offroad & 4x4
Feb 6, 2006 11:40 PM
Sandman1991
Jul 12, 2004 05:39 PM
TigerfaninNC
May 4, 2004 01:51 PM
GeoTracker
1978 - 1996 Big Bronco
Apr 24, 2003 10:00 PM
