bed rail help
Old Sep 1, 2025 | 07:21 AM
330pbr's Avatar
330pbr
bed rail help
is there a different spacer that goes between the rails and frame other than the small rubber pads?
just sitting on the pads the wood hits the frame rais(do i have to notch them 2 boards out?)
also is this steel shim in correct spot?
Old Sep 1, 2025 | 07:28 AM
55F250's Avatar
55F250
AirForceVet
What are you working on?
Old Sep 1, 2025 | 08:02 AM
330pbr's Avatar
330pbr
56 f100
Old Sep 1, 2025 | 08:30 AM
55F250's Avatar
55F250
AirForceVet
56 f100
I'm not sure I am understanding your question. This is what my bed looks like where the wood blocks are.
Old Sep 1, 2025 | 08:34 AM
330pbr's Avatar
330pbr
i see .....i didnt no about the wood blocks. how thick r they? do i need 8 wood blocks?
how about the steel shim
Old Sep 1, 2025 | 08:38 AM
abe's Avatar
abe
You're comparing F100 and F250 beds . F100 beds do not have wooden blocks.
Old Sep 1, 2025 | 08:42 AM
55F250's Avatar
55F250
AirForceVet
Yes, 8 blocks for the long bed, I'll have to find the dimensions and get back to you. The 4 that are on each side of the differential are angled for the hump.
Old Sep 1, 2025 | 08:44 AM
55F250's Avatar
55F250
AirForceVet
[QUOTE=abe;21649366]You're comparing F100 and F250 beds . F100 beds do not have wooden block
Last edited by 55F250; Sep 1, 2025 at 08:46 AM. Reason: didn't notice he mentioned f100
Old Sep 1, 2025 | 10:46 AM
330pbr's Avatar
330pbr
im working on an f100....6 1/2 bed
if im not to use wooden blocks do i have to router the 2 boards that bolt down to the frame?
i hav2 thick pads in the rear...4 thin in the middle rails and have a large gap on the front rail
Old Sep 1, 2025 | 12:26 PM
55F250's Avatar
55F250
AirForceVet
I wouldn't think you would have to but I'm not familiar with the 1/2 ton trucks. What do your crossmembers look like? My headboard bolted directly to the frame, I put a rubber isolator pad in between.
Old Sep 1, 2025 | 06:06 PM
8pack's Avatar
8pack
OT for this thread now but I Just did mine 2 weeks ago and there was no standard size for the block. The middle 2 rails have 4 of them that have to be cut at an angle to accommodate the frame shape and they were all different. It seems to me that the distance is different on each truck although I imagine they were cut to a standard size from the factory. But that was before 70 years of use.
There may in fact be a standard block size but on mine I found them all to be just slightly different.
Old Sep 2, 2025 | 06:43 AM
ManFordman2's Avatar
ManFordman2
I found this in the related post:
And you may have to c'bore or drill the two boards at the forward frame.
Old Sep 5, 2025 | 06:42 AM
Vegastype's Avatar
Vegastype
My 49 bed required no notching, it just sat on the rubber pads.
Old Sep 5, 2025 | 09:02 AM
56panelford's Avatar
56panelford
With all four cross rails in place you shouldn't have to do anything other than laying the boards down and secure them with the bed strips ..boards should clear the frame rails by 1/4" approximately ..
The plywood floors on the panel trucks were routed out at the frame rails though.. Don't mess up your boards ,they are too expensive..
Old Sep 14, 2025 | 06:38 AM
330pbr's Avatar
330pbr
i have a 3/8 gap on my front rail as u can see in the picture
and as you can see my wood is not clearing and cant figure it out
