Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1969 c750 decode pls
Old Aug 31, 2025 | 10:40 PM
Aligater's Avatar
Aligater
Recently bought an old fire truck, just curious to see what details the decode can provide. TIA.
C75FUE92282
153 C752 A291 M HOD
25500 194 3800 B18474
Old Aug 31, 2025 | 10:42 PM
85e150's Avatar
85e150
Tomorrow........
Old Aug 31, 2025 | 10:45 PM
Aligater's Avatar
Aligater
No rush, it only took 5 years to find one I had to have.
Old Sep 1, 2025 | 04:01 PM
85e150's Avatar
85e150
C75FUE92282
C75 = C750
F = 391 4V FT gas V8
U = Louisville Assembly Plant
E92282 = 1969 numerical series, March 1969 production
153 = 153 inch wheelbase
No color code. Truck is a special order so paint was probably part of that.
C752 = C750, 25,500 lbs GVWR
A291
A2 = Grey Twill Stripe Vinyl and Woven Plastic
91 = Tilt cab, Standard Custom Cab, Cab and Chassis vehicle (EDIT: Correction)
M = Clark model 285V five speed direct transmission
HOD
HO = Not listed. Could it be "HQ"? Is it a single speed axle?
HQ = Eaton model 17121 single speed rear axle, 18,500 lbs capacity, 7.17 ratio
D = Ford-Rockwell (Timken) 7,000 lb capacity front axle
25500 = 25,500 lbs GVWR
194 3800 = 194 Certified Net HP @ 3800 RPM
B18474
B1 = Ford of Canada, Central (Lincoln-Mercury) District Sales Office
8474 = Special Order Number
Old Sep 1, 2025 | 04:14 PM
Aligater's Avatar
Aligater
Yes it is a single speed rear axle, at first glance it looks like an O but there is a vauge indentation making it actually a HQ.
I would say ragoon red or something close to it, possibly a custom color. 🤔
The only deviation is that it is a custom cab, I would have thought that would show up in the decode but non the less, thank you for breaking it down for me.
Old Sep 1, 2025 | 04:22 PM
85e150's Avatar
85e150
Custom Cab should have showed under the "A291" part of the decode. A quick look and a little slower reading reveals it is a Custom Cab. With the alpha first, the "A2" indicates Custom Cab. Numeric first, "2A", would be Standard Cab. Sorry, should have read that more carefully.
Old Sep 1, 2025 | 05:25 PM
Aligater's Avatar
Aligater
No worries at all, it's the little things that can't be seen or known that I was interested.
Old Sep 1, 2025 | 05:45 PM
85e150's Avatar
85e150
Does that truck have a pump in the driveline?
Old Sep 1, 2025 | 09:00 PM
Aligater's Avatar
Aligater
It did, but the previous owner removed it and most of the apparatus.
Old Oct 12, 2025 | 09:03 PM
Aligater's Avatar
Aligater
Would it be possible to get a king pin part number, thanks.
Old Oct 13, 2025 | 12:35 AM
85e150's Avatar
85e150
Long shot sources for king pin kits. You have a 7,000 lb axle and that's how the kit is determined:
https://www.ford-trucks.com/forums/1...l#post18710776
My eyes have glazed over looking at the MPC. I'll try again tomorrow.
weasel068
Large Truck
Feb 8, 2025 09:32 PM
MotorMouthGarage
Large Truck
Nov 22, 2024 06:13 PM
Pineoakbundle
Large Truck
Jun 26, 2024 11:00 PM
hoyt1995
Large Truck
Mar 25, 2024 03:52 PM
oldjunkbuilder
Large Truck
Oct 1, 2014 07:23 AM
