Xela's '03 Mod and Maintenance Log
Old Apr 30, 2026 | 11:10 AM
  #31
Xela's Avatar
Xela
Originally Posted by JoshHefnerX
Interesting airbag setup. Like to see how this turns out. Seems like getting a B&W with airbags to fit together is always a bit of fab, and nothing really looks like that great of an option.
Yeah, I think I could have something clean and much simpler with the standard Firestone airbags as well, but I'm glutton for punishment. I always fall down the rabbit hole of "what if" when I'm building custom that often slows me down, then I often still end up with a less ideal final product...
Old Apr 30, 2026 | 02:08 PM
  #32
Tpayne621's Avatar
Tpayne621
I just welded the upper bag mount to the B&W side plate. Then just used the standard bracket on top of the u bolt plate on leaf spring. No weird brackets or anything and I would consider it pretty simple setup.
Old Apr 30, 2026 | 02:54 PM
  #33
FordTruckNoob's Avatar
FordTruckNoob
I did what @Tpayne621 did too.
Old May 7, 2026 | 10:23 AM
  #34
Xela's Avatar
Xela
Hard to really see what is happening in this photo, but I finished the bag setup. This is my "test" and it includes a 1" white spacer at the bottom. The idea is that I could remove that spacer and the black cradle on top of it and bag would never touch the plate while daily driving empty. The thought was that this would give a better unloaded ride, but I doubt I will ever remove that spacer. Can't wait to toss this bed out and start the flatbed.
Old May 7, 2026 | 10:39 AM
  #35
Tpayne621's Avatar
Tpayne621
I definitely wouldn't fool with removing anything for daily driving. I let all the air out of mine to 0 unless I towing camper and you don't even notice them.
Yes I know it says don't do that.
Old May 7, 2026 | 10:47 AM
  #36
JoshHefnerX's Avatar
JoshHefnerX
Is that black cup one of the daystar cups - or something similar?
Looks like a clean install though. Not all kinds of brackets everywhere.
Old May 7, 2026 | 12:07 PM
  #37
Xela's Avatar
Xela
I think this style of bag can run 0 PSI, but I'm not sure why it really matters for either style bag. I do think I'll end up removing the spacer eventually, but I need to do some testing first.
Yes it is a daystar knockoff. Unfortunately Daystar was OOS (and still are) but eventually I'd like to swap them out for the real deal.
This is still a proof of concept for me, and I'll be loading up the camper for the Memorial Day weekend for a first test.
Old May 7, 2026 | 03:35 PM
  #38
Tpayne621's Avatar
Tpayne621
I've never had a single issue running them at 0. Have airlift kit on mine for about 10 years or so now.
Old May 7, 2026 | 05:45 PM
  #39
John in OkieLand's Avatar
John in OkieLand
I added air bags "inside the coil springs" on my Suburban.
Instructions stated 10 psi minimum.
bought the Excursion, and forgot about the air bags. the lines had a tiny leak,
and now the airbags won't air up anymore.
I think the Suburban air bags were not tested for psi over at least 18 months.
probably more, LIFE got in the way, for two years, moving my sister from Utah.
tmacc
27
Mar 4, 2024 07:18 AM
Compression-Ignition
Feb 6, 2023 11:41 AM
PatSlab
19
Sep 27, 2022 10:32 AM
ddqarch
Sep 9, 2020 07:51 AM
RanchTruck07
Mar 8, 2012 03:13 PM
