EBP sensor reading high
Old Aug 26, 2025 | 04:38 PM
Noah100's Avatar
Noah100
Trailering
95 7.3 auto with EBPV delete pedestal
I've cleaned out the tube. But the sensor is reading high KOEO. 21.1 psi. MAP is reading 14.7. Also have P0476 code. Probably time for a new sensor?
Old Aug 27, 2025 | 08:56 AM
knottyrope's Avatar
knottyrope
MAP, BARO, EBP should all be the same at KOEO
If EBP gets too high, PCM will defuel and can cause weirds shifts with an automatic
Old Aug 27, 2025 | 09:11 PM
Noah100's Avatar
Noah100
Trailering
New EBP sensor. That looks better. Should I be concerned about BARO?
Old Aug 28, 2025 | 09:37 AM
knottyrope's Avatar
knottyrope
BARO can defuel as well if it think you are in the thin mountain air
Mine thought it was at 10k feet and ran sluggish
I pulled mine and it ran at full power after
lil black thing under steering collum
pics in this thread
https://www.ford-trucks.com/forums/1...-sensor-2.html
Old Aug 28, 2025 | 11:01 AM
Noah100's Avatar
Noah100
Trailering
pics in this thread
OK I will definitely try that next. Thankyou
Is there one in the engine compartment? I have this sensor im pretty sure attached to the fuel bowl wiring harness?
Old Aug 28, 2025 | 11:32 AM
knottyrope's Avatar
knottyrope
thats the Water In Fuel Module
BARO is NOT in engine compartment
Old Aug 28, 2025 | 01:20 PM
Noah100's Avatar
Noah100
Trailering
Makes much more sense. Will check and report back!
Gwilkrrs
Aug 26, 2022 10:19 AM
Dave042
20
Feb 12, 2019 02:20 PM
Silverhks
Jul 22, 2018 05:44 AM
comtb
Dec 31, 2016 02:59 PM
Benny2002
Jul 8, 2007 11:25 PM
