Tailgate pop when opening
Old Aug 22, 2025 | 07:41 PM
FOURBYBUD's Avatar
FOURBYBUD
2025 F250 Lariat. Tailgate latch seems really loud when releasing to open. Makes a loud pop. Everything seems fine and working correctly. Anyone else have this?
Old Aug 23, 2025 | 06:33 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The definition of "loud" is pretty subjective to different people, but yes, the loud pop is normal.
Old Aug 23, 2025 | 08:25 AM
FOURBYBUD's Avatar
FOURBYBUD
Agreed, it is just loud enough to startle anyone around. I checked out everything and all seems good. I'll give it some time and maybe it will "break" in a little more quietly. Lol
Old Aug 23, 2025 | 09:28 AM
6.2caribou's Avatar
6.2caribou
Is it the sound of the latch unlocking that's loud or does it happen as the tailgate is lowering? When I got my truck, the tailgate made a loud popping or cracking sound as it lowered, which came from the cable catching the tie down bracket as the cable straightened out
Old Aug 26, 2025 | 05:16 AM
shailey's Avatar
shailey
Mine does this, too. The bed on my 24 F350 is slightly out os alignment due, I think, to inconsistencies in the frame - the left rear is about a 1/2” lower than the other three corners. I complained to my dealer about this and he said that they “openned a case with Ford”, whatever that means.
Mine has gotten a bit better (less of a bang when opening the tail gate) as the truck has aged. I’ve learned to live with it.
I don’t expect any resolution from Ford about the misaligned tailgate. This truck was a special order and I didn't notice this issue during the delivery inspection.
Old Aug 26, 2025 | 06:59 AM
FOURBYBUD's Avatar
FOURBYBUD
I've adjusted the strikers so gate is flush on both sides when closed. Noise is getting a little better. After looking at it I'm thinking the tailgate is just a bit twisted if that makes sense. Driver's side has slack in cable when open, yes I know that's normal, but drivers size also closes about 3/8in before passenger side. Either way, not thrilled with body work on a new truck. Prolly just leave it alone.
Old Aug 27, 2025 | 12:39 AM
wcbcruzer's Avatar
wcbcruzer
...it is just loud enough to startle anyone around.
Mine does not do this. In fact, I wouldn't even say it's loud. Do you have to kind of slam it to close? Seems like the latch or hinge is a tiny bit off adjustment.
Old Aug 27, 2025 | 02:49 PM
acdii's Avatar
acdii
There are two torsion rods at the bottom of the tailgate that need adjustment. If you open the tailgate and look at the very bottom you should see a screw on the right side. I forget the procedure to adjust them, but what you are hearing is the rods popping as tension is removed.
This is from a 2012, but same design. BTRV had a video on his 2017 F450 as well, couldn't find it though
Vinford
Feb 10, 2024 06:09 PM
BuiltTough45
Apr 27, 2021 11:42 AM
MooManChu
Jun 12, 2019 11:32 PM
