Driver side battery cover.
Old Aug 22, 2025 | 05:17 AM
Kingair90's Avatar
Kingair90
Hello Ford family.
I have an issue with my the PCM, in two years am going on the second PCM can't figure out why but someone on the chat mentioned the battery cover was the cause of having the problem with the PCM as he said; I lean the hard way.
My truck doesn't have a battery cover and if I Hader known, I would have taken it from the other truck before I sold it. Should that be the true cause where could I find one.
I been looking now online for days including the dealership but having seen anything.
If anyone have that information that the battery cover is the problem and I can get hold of them, please, give me an idea where to look for that cover,
Thank you
Regards
Kenneth Leerdam
Old Aug 22, 2025 | 05:27 AM
bismic's Avatar
bismic
I don't follow the logic (unless the degas bottle is puking a lot), but have you done a search using the part number (maybe EBay)?
3C3Z-10A659-BA
https://www.ebay.com/itm/27622466012...tion=view_item
Old Aug 22, 2025 | 08:11 AM
TooManyToys.'s Avatar
TooManyToys.
Usually, the PCMs themselves are well sealed; it's the harness and PCM connectors that are most prone to corrosion from the battery acid and vapors.
If you want a more secure situation that the porus cover itself, which will not protect against leaks around the battery posts (vapor and liquid), if your region of the country uses these types of batteries from Walmart with a nipple vent so a hose can be pathed under the frame, or an AGM battery (Walmart cheapest), which is sealed, will be better.
Old Aug 22, 2025 | 08:32 AM
bismic's Avatar
bismic
Hey, how about posting a pic of the driver's battery posts and cables? PCM connectors also.
Man its been a long time since last dealing with cable corrosion!!! It is NICE.
Old Aug 22, 2025 | 08:34 AM
Kingair90's Avatar
Kingair90
Hello Bismic, thanks for dropping in.
Yes, I did try the part number but was not successful.
I will continue to try.
Have a great weekend
Best Regards
king90
Old Aug 22, 2025 | 08:37 AM
bismic's Avatar
bismic
The EBay link I posted above isn't a possibility? Looks to still be available. $70
Old Aug 22, 2025 | 08:59 AM
Kingair90's Avatar
Kingair90
Mr. Bismic.
Thank you very much for your help.
I don't know what happened, but I have five days searching Ebay and all the others.
Thank you
Highly appreciated
King90.
Old Aug 22, 2025 | 09:24 AM
bismic's Avatar
bismic
That is how EBay treats me also. Sometimes searches find things and sometimes they don't. I just hope it is legit and still available for you.
Old Aug 22, 2025 | 09:36 AM
Kingair90's Avatar
Kingair90
Yes, I was directed to the seller because Florida was not in his / hers shipping list. I sent him / her my broker address in Florida to see if they will ship.
Thank you, I appreciate your help whether its workout or not, I got a good lead to continue.
Have a great weekend.
King90
Speedjester
Jan 29, 2011 12:59 AM
Super Steve
May 28, 2008 04:30 PM
jfsully
Electrical Systems/Wiring
Aug 29, 2005 11:45 AM
