Power window
Old Aug 14, 2025 | 10:42 AM
kenny nunez's Avatar
kenny nunez
Question Power window
The power windows do not work. They would not work with the door open, only closed. Is there a problem with a broken wire in the harness?
2007 F 150.
Old Aug 15, 2025 | 04:09 AM
techrep's Avatar
techrep
yes... gotta open up the loom and troubleshoot.
Old Sep 7, 2025 | 10:13 PM
boots6868's Avatar
boots6868
Just be through this myself started off with passenger window didnt work nor the rear windows but driver side did have control then i had to open my driver door a little to get the window to work. Then one day that trick didn't work anymore .
I finally cut open the loom and carefully sorted through the wires and by golly there were two wires completely severed. Ground and power to other side . Did the best I could in the tight space and it works perfectly now. Check it out.
F-150 MP
2004 - 2008 F150
Jul 30, 2015 08:38 PM
mrpositraction
2004 - 2008 F150
Oct 18, 2007 11:10 AM
mxmadman374
Electrical Systems/Wiring
May 6, 2007 12:26 PM
zigzkidz
Mar 29, 2007 05:15 PM
selorentz
Apr 16, 2002 01:16 PM
