Tire pressure double check
Old Aug 12, 2025 | 06:59 PM
N600's Avatar
N600
My new-to-me '97 F250 with 7.3 Powerstroke has Michelin 285/75R16's on it. The door sticker says to run 55psi to 80psi for tire pressure and the tires have 80 psi stamped on the side. This topic doesn't search well and is confusing. Plus I may have already asked it.
What should I run for normal summer rural open road travel? I'm thinking 55 or 60 psi all around?
How about with 8,000 to $9,000 lbs of bumper hitch trailer on the back? F--65 psi. R-- 70 or even 75 psi. psi?
What do you think?
Thank you.
Old Aug 12, 2025 | 07:11 PM
97-psd's Avatar
97-psd
I think you are on the right track. I run around 55-60 when empty. Maybe a touch more if I am loaded. Depending on tongue weight of the trailer, maybe 65-70.
Old Aug 12, 2025 | 09:25 PM
N600's Avatar
N600
Thank you.
Old Aug 12, 2025 | 09:49 PM
helifixer's Avatar
helifixer
35 rear 45 front when empty.
if i am towing a heavy trailer I will go up to 80 rear and 70 front.
Old Aug 13, 2025 | 06:19 AM
97-psd's Avatar
97-psd
how does it drive with 35 on the rear? You have an exceptional attention to detail and I would be interested to know more about how you settled on that value.
Old Aug 13, 2025 | 07:52 AM
helifixer's Avatar
helifixer
I always aired down when ELK hunting, 35 takes a lot of the roughness out when on dirt roads. one year I didn't air them back up after hunting and liked the way it rode. no change in handling and no change in fuel mileage.
Old Aug 13, 2025 | 12:14 PM
ashleyroachclip's Avatar
ashleyroachclip
I run 315/75/16 , so a 35 ,E rated tire , and run them at 45 all 4 all the time .
tire wear is flat across the tread , and I do get 65k miles out of a set .
Old Aug 13, 2025 | 07:26 PM
97-psd's Avatar
97-psd
I may air mine down and see how it does. I went with air bags years ago and it helped quite a bit. Airing down the tires should interesting. I need to install the front shackle reversal kit too.
Old Aug 13, 2025 | 07:29 PM
N600's Avatar
N600
I'm not familiar with the front shackle reversal kit. What does it do and who sells them?
Old Aug 13, 2025 | 08:38 PM
Harveyearlolstad's Avatar
Harveyearlolstad
The RSK kit moves the leaf hinging shackle to the rear of the leaf spring. For some reason the factory place it in the front. When hitting a bump the leaf/axle bounces against you as opposed the bouncing toward the rear moving along with the motion of the truck when placed in the rear of the leaf. I noticed a more crisp ride. But it's still a solid d60 axel so it's never going to ride like a dream. You would also purchase the upgraded SD leafs which are a little longer adding a little travel in the leaf. The standard kit also levels out the truck which gives it a better stance. In addition it ties your frame rails together making things more stronger/secure.
Pmf and sky makes the kits. I didn't find it hard to install. Some drilling require. I added a hitch to mine for a little more $ as an option
Old Aug 15, 2025 | 06:33 PM
N600's Avatar
N600
Good explanation. Thank you.
1L243
Nov 11, 2020 10:25 AM
GatorBait1996
Jan 5, 2011 12:14 PM
rb8484
Apr 1, 2009 10:24 AM
bigredtruckmi
Oct 22, 2008 03:37 PM
pezley69
1978 - 1996 Big Bronco
Apr 1, 2003 01:52 PM
