Wood for the bed
by 5 1/2inches wide and 5/8 inch thick. There are recesses along both edges of the top surface as I tried to show in the first photo. The wood is not a hardwood and not particularly choice as seen by the knot.
I originally looked into replacing my wood with teak until I found out how expensive it is. I am looking into using a type of wood, I believe is from Brazil and is used locally for decking. It is very hard and is also used in semi-tracker trailer rigs, too.
Also, according to the LMC catalog there are 8 boards and the two that butt up against the bed sides need to be cut for clearance around the wheel arch.
This is the top surface of the only original board I saved from my flareside as reference. on BOTH edges there is a 1/16 deep by 1/2 inch wide recess, or rabbet (or Rebate) in woodworking terms
bottom side. note the presence of a knot, which should give you an idea of the quality of the wood. Likely a soft wood such as pine
Edge view attempting to show the depth of the recess. The photo is a little misleading, I think due to the dirt and foreshortening of the angle.
Last edited by jalls1; Aug 6, 2025 at 10:55 PM. Reason: missing additional information
I think what "jalls1" might have been thinking about as an alternative is IPE as it is a very dense hardwood with lovely dark Mahogany color that would look very nice against the blue of your truck. It is expensive, has to be predrilled and you have to use Stainless steel screws as the wood will react with normal metal. It is bug resistant and somewhat rot resistant, but does need to be oiled to keep the lovely color, or it will slightly grey over time if left untreated.
Another option might be Bamboo. I have done some decks with thermally modified bamboo, that I really like. One, it has a pleasing dark finish that is slightly less red than IPE. Two, as a pressed and engineered material, it is very rare, to have a board that is warped, at least not that I have experienced, and it is very dense. Three, the system that I have ordered, has had a 25 year warranty against rot, water and weather won't bother it, and while it is better to condition it and or oil it, if you leave it, it will still look pretty good even after direct contact with the weather for several years (as one of my customers can attest). What I am not sure about, or remember is what the tenth of the boards are, and they might not be long enough.
Naturally, Oak, Walnut, Ash, would all be nice woods, are hardwoods and likely hold up well if treated (oak you can leave untreated and it will only water and become soft and luxurious over time but last years).
When you decide what you want, and find out the dimensions you need and quantity, I would be happy to plane and make the boards for you if we can figure out how to get them to you.
Be well and keep the post coming, it is nice to see your progress and great craftsmanship!!
has a nice diagram with dimensions. Slightly different from what I noted.
And yes, I was referring to IPE. I did not realize it reacted with normal steel. I need to look into the modified bamboo. I have recycled bamboo in my house that I installed and I like it but the extra pieces that I stored outside molded quite a bit. I was also considering TREK decking wood but putting it through a planer could be a nightmare.
