Sponsored by: Auxito
Throttle Body Cleaning
Old Aug 4, 2025 | 07:02 PM
F150_4x4's Avatar
F150_4x4
Just cleaned my throttle body for 10th Gen F150.
Roughly 2 years has passed and mostly Shell regular unleaded gas was used.
12000-15000 KMs distance since last throttle body cleaning.
I'm surprised how relatively clean it was.
Very small amount of carbon past throttle plate.
The front throttle plate looked relatively clean.
Does this mean that the fuel has adequate additives in it?
Old Aug 5, 2025 | 06:12 PM
Blondie70's Avatar
Blondie70
I would say it means you have good air filters !!!
Old Aug 5, 2025 | 10:48 PM
F150_4x4's Avatar
F150_4x4
Basic Fram model air filter changed a couple years ago.
I remember it wasn't dirty much back then.
Should I change it if it's not that dark ?
Does a new air filter periodically changed keep mass air flow sensor cleaner ?
Old Aug 5, 2025 | 10:54 PM
RLXXI's Avatar
RLXXI
Get that Fram outta there and replace it with a Ford or Motorcraft for best results. Everything that gunks up the intake and sensors goes thru that filter, oem is best.
Old Aug 6, 2025 | 08:54 PM
F150_4x4's Avatar
F150_4x4
Just changed the Fram air filter to a Motorcraft air filter.
Attached are pics of the Fram Air Filter with roughly 15 000 kms. Looks pretty dirty but the intake hose that leads to the EGR is spotless from dust and debris.
Looks like exactly the time to change it. 2 yrs old.
Old Aug 7, 2025 | 01:15 PM
F150_4x4's Avatar
F150_4x4
The WIX air filter is made up of enhanced cellulose and for half the price of the Motorcraft air filter. Motorcraft material on air filter is not described anywhere. WIX Easily available here locally and the WIX outsells the Motorcraft times over and with better reviews.
Old Aug 9, 2025 | 12:24 AM
Oregon Kickstart's Avatar
Oregon Kickstart
I was just curious what you guys think about reusable K&N filters... I have one on my 2001 5.4l SCrew that I recently scrubbed out and re-oiled...
Old Aug 9, 2025 | 07:30 AM
manicmechanic007's Avatar
manicmechanic007
Not a fan of oiled filters
They are bad on the MAF sensor with the 2 hot wires inside
They put a film on the hot wires that make up the sensor
That film requires you to clean the maf occasionally to make it run right
Old Aug 9, 2025 | 02:09 PM
Oregon Kickstart
So, what would I use to clean the MAF sensor? Like carb cleaner, or electronics cleaner (switch and tuner cleaner)?
Sounds like next go around I'm going to put a regular filter back in...
Old Aug 9, 2025 | 06:28 PM
F150_4x4's Avatar
F150_4x4
If you clean the MAF while it is still on the intake ...
The red sensor that is on the MAF is not visible...
Should the entire MAF be removed to be sprayed ?
Can't it be done while it's still attached to the intake ?
I don't want to take it apart and have trouble installing it correctly again.
Old Aug 9, 2025 | 06:31 PM
Blondie70's Avatar
Blondie70
I clean mine while attatched to the pipe.
Old Aug 9, 2025 | 07:23 PM
F150_4x4's Avatar
F150_4x4
Ya but aren't you suppose to spray both sides ?
If it's attached to the pipe, can you spray the other side effectively?
Old Aug 9, 2025 | 09:56 PM
manicmechanic007
They make special mass air flow sensor cleaner
Old Aug 9, 2025 | 10:00 PM
manicmechanic007
After I check the MAF PID and voltage out of the sensor
I take them off
I take them apart
I touch both of the hotwires with a pocket screwdriver and move them slightly
Sometimes you find a spider web in there
You need to take the cover off to find those
mayerst
Jan 9, 2022 07:10 PM
Treacy
Jun 21, 2021 07:33 PM
dremtofford
Feb 23, 2021 09:21 PM
Jlckb5
13
Nov 1, 2011 10:14 AM
operator414
27
Mar 24, 2008 02:42 PM
